Old 09-08-2015, 11:49 AM
john1192 john1192 is offline
Default Track Input Monitoring in 12.2
note: unless i am doing something wrong .. input monitoring in 12.2 is useless in Vanilla .. i far as i know it only really works in HD with hardware .. so my Lynx card and PT do not speak to each other like HD software and hardware .. so even though my lynx card has Sub 1ms latency it cannot be used with PT software .. oh well .. at least the meters are cool
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Last edited by DigiTechSupt; 09-28-2015 at 09:20 AM. Reason: Off Topic post moved to new thread.
Old 09-08-2015, 11:59 AM
Default Re: Track Input Monitoring in 12.2
Does the Lynx hardware monitoring support Pro Tools low latency monitoring (LLM)?
Input monitoring will be doing what it does regardless, that is managing if tracks are monitored or not, how punch ins work etc. It cannot create a magical low latency path, if you want low latency this way you need to turn the buffer size as much as possible or utilize an interface that provides LLM support (which leverages the onboard hardware mixer in the interface--and the Lynx at least has that, check with the manufacturer if they offer LLM support).
Track Input monitoring!? realizment macOS 9 11-04-2013 01:51 AM
Monitoring input and track during playback simonyeah Post - Surround - Video 5 09-24-2012 03:07 PM
track input monitoring vin7 Pro Tools 10 6 08-28-2012 07:08 PM
Pro Tools Track Input Monitoring??? MLH Studios Inc. Pro Tools 10 13 03-13-2012 11:03 PM
Single track Input Monitoring?? sylviesongs macOS 1 09-19-2011 01:41 PM
