Old 06-29-2015, 08:26 AM
Armando Armando is offline
Default TC Level Pilot w/Control 24??
Has anyone tried using a TC Electronic Level Pilot volume knob with their Control 24?
The stepped knob on the console has always bugged me and this looks like a simple, relatively cheap solution. Guess I would just need to max out the board's main output knob to full and use the Level Pilot for smooth volume adjustment.
Thanks in advance!!
Armando
Old 06-29-2015, 09:40 AM
groundcontrol's Avatar
groundcontrol groundcontrol is offline
Default Re: TC Level Pilot w/Control 24??
This would work only if you're using Core Audio.
Why not bypass the console monitoring section completely then?
Can you please send yourself over fiber to go spam some other forum?
Darryl Ramm
Old 06-29-2015, 10:04 AM
Well, the Control 24 has the monitor out(1-8) breakout snake, I could patch the Level Pilot's cables between them and my powered monitors. Then I assume I'd would only need to set the Control 24 master level knob set to "full" and control the level output from the Level Pilot. That should also allow functionality from the Control 24's extra Monitor section's controls like, Mute All, Dim, Mono, etc....
Armando
FS: Black Lion Audio White Sparrow D/A with TC Electronic Level Pilot $1600 whittybeats Buy & Sell 3 10-21-2014 03:20 PM
FS: TC Electronic Level Pilot crandallwarren Buy & Sell 1 06-30-2014 06:10 PM
7.2 MIDI Bug? Suck? or Pilot Error? RobMacki Pro Tools TDM Systems (Mac) 3 11-29-2006 08:00 AM
7.2 AudioSuite Bug, settings, pilot error? RobMacki Pro Tools TDM Systems (Mac) 0 11-03-2006 04:51 PM
plug in count for palm pilot coaster General Discussion 19 02-16-2001 01:55 AM
