Behringer X32 Compact and Pro Tools
I recently received the Behringer X32 compact and am trying to connect it to my 2.4Ghz Intel Core 2 Duo MacBook with 4GB ram. Everything seems to be in place, I'm running a USB from the UXF to my computer. I tried setting the peripherals on pro tools to HUE (if that's correct) as well as the peripherals on the board, etc. The computer just doesn't seem to recognize the UXF. When I try to set that in peripherals it simply doesn't show up. Can you help me with this issue asap? I've been looking all day for firmware/drivers I may need for the UXF and am unsure of what I need. Thank you so much and let me know ASAP if you have any advice.
Re: Behringer X32 Compact and Pro Tools
it's in the playback engine no drivers needed - Just make sure the console is on BEFORE launching PT
It is possible to use 8 of the x32 faders as control faders for the mix page of protools.
HUI must be enabled and I think there are a couple more settings to fix. It's all covered on the behringer user forums. Here is a youtube: https://www.youtube.com/watch?v=bEVpQaMg3PQ |
I had an issue with my Macbook Pro (2009) and the X32 recently trying to go into Pro Tools 11.
The driver would not be detected unless I plugged into the USB port closest to me (facing the computer of course). Since I was using Pro Tools, the iLok was in the other slot. Probably reversing sucked too much power due to how the USB ports are wired up. Just wanted to throw that out in cyberspace in case someone else is beating their head looking for drivers when it's just a simple switch of the port. |
Can't record midi notes in pro tools 8 with Novation SL compact | freaken | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 06-16-2010 07:55 AM |
Pro Tools LE and TC Powercore compact | indoe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 01-02-2006 06:38 PM |
behringer mx9000,behringer mx3282A,mackie 24/8buss | JOAN ROSALES | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-03-2004 12:21 AM |
Anyone using Trident S100 with Pro Tools? Any other high end compact mixer? | scottlmicu | Pro Tools TDM Systems (Mac) | 0 | 04-03-2003 01:40 PM |
BEHRINGER MX-602A Super Compact Mixer | andyo | General Discussion | 7 | 04-01-2002 07:47 PM |
