Removing unauthorized UA plugs in Windows
Now that UA have released AAX versions for windows I have every UAD plugin that I don't own in my plugin lists. Other than purchasing all of them is there a way to only display the ones I have?
Re: Removing unauthorized UA plugs in Windows
I don't know if UAD has separate .aax files for their plugs but you could look in the used plugins folder and if there are just move them to the unused plugins folder (do this with PT closed). Delete the PT11 databases and PT will rescan the plugins on next startup and you should not see the plugins you don't own. Unfortunately you'll have to go through this every time UAD has a software update.
I didn't know the first thing about where Pro Tools was installed or where various assets resided but I was determined to sort out my plugins to regain my sanity.
After some searching around I found my UAD plugins here... C:\Program Files\Common Files\Avid\Audio\Plug-Ins\Universal Audio I selected all and then ctrl+clicked my authorized plugins to remove the from the selection. Once this process was carefully complete I used CTRL+X to cut them from the folder and they all turned semi transparent. From there i navigated back to... C:\Program Files\Common Files\Avid\Audio\Plug-Ins (Unused) ...and pasted them here. I restarted the computer, launched Pro Tools 11 and opened my last project. Checking the plugins available for insert showed my newly culled list. Problem solved! I did not have to delete the databases folder. |
You wouldn't have to delete the databases folder just the PT database itself. There's a nice utility program specifically for Windows that takes care of such things and it's called Trasher and is done by one of the people who post here. |
No worries, I'm a very comfortable computer person. I built my first computer in 1984 and have been programming and using some kind of personal computer in my life since then. I've been using PT since December but I haven't really had to investigate the file structure for any reason. Adding to the confusion is having PT 10 and 11 installed at the same time. Just about everything I found in searches was related to OSX and involved trashing databases which was not necessary for me in Windows 7.
Waves Plugs & Windows 7 64 bit ??? | Mr. Kelly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 16 | 07-27-2010 01:17 AM |
Waves plugs, & Windows 7 ??? | pianosound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 22 | 09-07-2009 10:26 AM |
How do u bypass a plugs delay without removing it | olzzon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 06-22-2006 08:34 PM |
Removing all plugs and sends ..... | Don Geppert | Tips & Tricks | 1 | 04-02-2005 05:18 AM |
McDSP Plugs Now Available for Windows XP!!!!!!!!!! | gonzo99 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-15-2005 11:15 PM |
