audio disruptions every 60 seconds
I'm new to protools and just started using the tool with version 11. No matter what project I have open, roughly every minute I get a disruption in the audio, whether it is playing back, recording or even just running a click track. Having the resource window open, the processor section goes to 100% right as this happens. The microsoft proc monitor does not agree, so don't know what that means. I have tried every Windows 7 optimization I can find on the internet, including any BIOS adjustments.
I'm running win 7 64 bit sp 1 on an i7 4770k with Asus Z87-A motherboard. I have more than enough horsepower and resources to handle any of the tests I've performed. Using Eleven Rack is my interface. Any ideas?
Steve Win 7 Pro 64 bit i7 Haswell 16G Ram SSD system drive separate sample and project drives protools 11.latest eleven rack interface for guitar |
Re: audio disruptions every 60 seconds
Have you done the required optimizations?
Do you have any demo plugins? How are your hard drives connected? Are they non-green drives? How much ram do you have? Do you have any programs running you shouldn't while using PT? Do you have any kind of wireless network connection active while running PT (you shouldn't)? |
It seems I had something strange going on with my PCIe wireless card. After re-trying disabling it and re-opening pro tools and doing several iterations of this I finally have glitch free operaton while my wireless network adapter is disabled. Sweet! Not sure why it didn't work at first, but looks good now.
Thanks everyone.
Another working Haswell system.
You might want to run the DPC latency checker to see if any other drivers might cause issues. Have you run the Intel Extreme Tuning Utility performance test? This lets you compare your system to others with the same parts, settings etc.
"In theory there is no difference between theory and practice. In practice there is." - Yogi Berra Last edited by dave911; 01-31-2014 at 06:55 AM. Reason: stuff |
HELP!!
I am having the same problem. Started with 10.9.1 upgrade Currently running" OSX 10.9.1 2x3.2Ghz Quad Core Intel processor 10 gig RAM Problem happens when RECORDING with BOTH ProTools 10.3.7 AND 11.1.2 What can it be now?? |
Could be lots of things. What exact model Mac are you running? Are you running with a separate drive for PT to record to? Have you properly optimized your setup? You don't give enough info on what you're doing, what you're working with, plugins, etc.
I've tracked it down to having the internet connected.
How can I find out what internet activity is occurring every minute to cause this interruption? |
Doesn't matter what net activity is causing the problem the simple answer is to disconnect the internet cable or shut down your wireless. There's no need for it when working inside PT.
Weird sounding audio after few seconds | scontrer | Pro Tools 10 | 3 | 08-27-2013 01:57 AM |
PT HD8 getting clicks and only 5 seconds of audio repeated | bleeding ears | Pro Tools TDM Systems (Win) | 1 | 07-10-2013 05:14 PM |
MBox Pro 3G - Audio stops after 15 seconds | starkins | Windows | 2 | 07-05-2012 05:52 PM |
Mbox2Pro DROPS audio after seconds! | gizmoill | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-01-2008 01:42 PM |
002R audio dropout every 45 seconds | Greg B | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-24-2006 10:38 PM |
