Old 10-31-2013, 08:06 PM
realizment realizment is offline
Default Track Input monitoring!?
Guys,
Im looking for a clear description of track input monitoring and cannot find it anywhere. I know in standard pro tools the difference between the 2 global modes.
But With PT HD, users use the input monitor button while recording, I also see them use this when bouncing mix stem to another track, my question is what for both of these scenarios what does it do on individual tracks?
Why would you click this on the track your bouncing to if it is already in record mode wont you be hearing it anyways?
Thank you
Old 11-01-2013, 04:18 AM
Drew Mazurek's Avatar
Default Re: Track Input monitoring!?
Originally Posted by realizment View Post
Guys,
Why would you click this on the track you're bouncing to if it is already in record mode wont you be hearing it anyways?
Thank you
First, nothing can be in Input during a bounce. PT won't allow it.
The I button allows you to practice or play along with a track while not recording it. It also allows you to put a track in Input one line ahead of a punch so a singer can hear themselves ahead of the punch. I do this quite regularly.
Not sure I am answering your question though...
www.drewmazurek.com
Old 11-01-2013, 12:45 PM
Thank you. No I dont mean during an actual bounce, i mean when your bouncing to another track for example routing a submaster to a record track. I know guys who do this and that way if u change part of the mix you just have to bounce from that section updating your bounce? In this case i see them putting the input button on, but if the track is record enable why the input button also?
thanks
Old 11-01-2013, 01:06 PM
joachim's Avatar
joachim joachim is offline
Because you will not hear anything unless you record.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 11-01-2013, 01:40 PM
TOM@METRO's Avatar
Right. With input monitoring on you can audition the track without recording.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 11-01-2013, 01:41 PM
Thank you
Old 11-01-2013, 05:37 PM
I also use it with audio tracks and SD2 so I can hear everything during editing(the audio tracks in Input mode act like AUX tracks). Once I am happy, I put those tracks into record and print the drums as audio tracks.
Old 11-02-2013, 02:56 AM
joachim's Avatar
Track A outputs to track B, no audio on track B
audio material on track A , track B only record enabled , playback : nothing can be heard
audio material on track A , track B input monitoring , playback : audio material on track A can be heard (through B)
audio material on track A , track B record enabled , record: recorded audio material on track B can be heard
now there is audio material also on track B,
playback,
track B input monitoring on : audio on track A can be heard
track B input monitoring off : audio on track B can be heard
Old 11-04-2013, 01:51 AM
Thank you!
Monitoring input and track during playback simonyeah Post - Surround - Video 5 09-24-2012 03:07 PM
track input monitoring vin7 Pro Tools 10 6 08-28-2012 07:08 PM
Pro Tools Track Input Monitoring??? MLH Studios Inc. Pro Tools 10 13 03-13-2012 11:03 PM
Single track Input Monitoring?? sylviesongs macOS 1 09-19-2011 01:41 PM
Track Input Monitoring Toggle? Jamie Smith ICON & C|24 2 05-10-2007 05:12 AM
