Old 08-14-2013, 04:22 PM
Default Trasher 11, PT utility for Windows users
Just wanted to give a heads up that a build is ready for PT 11 and 10.3.5+
This build is put together for the co-install environment of 10.3.6+ and 11.
Trasher 10.5 also received an update (build 5.7) which serves PT 10.3.5+
To add to the confusion a bit, The functionality of either build is the same inside of PT 10.3.5-10.3.7
But if you are NOT running PT 11, It is easier to deal with the 10.5 build of Trasher.
ALSO: 11 does not support a 32 bit OS. If you are running PT10 on a 32 bit OS, you must use Trasher 10.5
A direct link is here to the page that contains the notes and builds. My signature also contains a link to a different thread.....yea I know.......that contains every build of Trasher supporting PT 7 to current.
Feel free to leave questions or comments here specific to 11 here and if you could direct any inquiries about 10 to here
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
Old 08-14-2013, 07:28 PM
19 frets 19 frets is offline
Default Re: Trasher 11, PT utility for Windows users
Just wanted to throw out an "atta boy" to guitardom for this great app. I was having a problem with PT 11 switching between ASIO4ALL and my RME UFX interface properly. As soon as Trasher 11 came out, I put a hunch to the test to use it to clear my prefs and it solved the problem. Now I have a work around until Avid can get the interface issue resolved.
Thanks again for this great app!!!
The full explanation is in this thread if anyone is interested:
http://duc.avid.com/showthread.php?p...73#post2071473
Old 08-15-2013, 07:35 PM
zedhed's Avatar
zedhed zedhed is offline
Great work 'G'! Your efforts are very much appreciated.
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 08-15-2013, 07:38 PM
louieshowers louieshowers is offline
i hope you get a complimentary version of PT 12 from Avid! Good job and thank you!
Windows 7 64 Ultimate: SP1
PT 10.3.8
¨WHERE´S MY CHECKBOOK?¨
https://soundcloud.com/louieshowers
Old 08-15-2013, 08:38 PM
zedhed's Avatar
Yeah +1!
HD 96I/O
Old 08-20-2013, 11:09 PM
Software is great, but I would prefer an Omni!
pro-tools-pc.com
Intel I7 9900k
Win 10
Old 11-24-2013, 07:51 AM
dannym dannym is offline
I'm trying to install Trasher 11 on Windows 7 64 bit.
I unzipped TRASHER 11.zip to my Desktop. That produced a folder called Data on my desktop. I opened that, ran the installer TRASHER 11 Installer.exe contained within, and clicked New Install, but got an error "The TRASHER 11 folder cannot be found".
Have also tried copying TRASHER 11 Installer.exe and the TRASHER 11 folder direct to my desktop and running the installer from there, but with the same result.
Am I doing something stupid?
Thanks!
Pro Tools 12.3.0, Molten Music Technology laptop (Clevo rebadge), Windows 8.1 Pro 64bit, dual i7-4800MQ, 16GB RAM, Focusrite Scarlett
Old 11-24-2013, 09:12 AM
Thanks!
Hello,
It seems there is a variable with different extraction programs. I will work on it when I can get some time.
If you have a problem, after extraction, drag the Trasher 11 folder into your Documents. The folder hierarchy in your Documents should be:
Documents>Trasher 11>App Files>Backups 10/11
If you navigate through the folders a couple levels, you will find a folder called .exe. Hold down control and drag (copy) the .exe onto your desktop or taskbar.
pro-tools-pc.com
Intel I7 9900k
Win 10
Trasher 10, a PT utility app for Windows users guitardom Windows 109 04-10-2024 06:36 PM
TRASHER for Windows 7 markus44uk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-23-2011 07:39 AM
Trasher support utility for PT9 and W7 guitardom Pro Tools 9 1 11-30-2010 10:17 PM
PT9 Trasher app windows 32 bit Raoul23 Pro Tools 9 3 11-24-2010 12:10 PM
Quicktime to Windows Media Conversion Utility hitp Post - Surround - Video 8 07-24-2004 01:27 PM
