Old 07-11-2013, 11:19 AM
Jeffrey Talbot Jeffrey Talbot is offline
Default Video Editing Bug
Ok so I realize that PT ISN'T designed to work as a video editor, however it does edit video differently that in PT10. Editing a video clip has very unexpected results. Simply creating an edit in a video clip causes the 2nd clip to not be continuous with the 1st.
No dragging or moving of either clips... just make an edit, and the clip is now not continuous.
Old 07-11-2013, 02:44 PM
Question Re: Video Editing Bug
What codec was used for this video?
Old 07-15-2013, 01:04 PM
Default Re: Video Editing Bug
H.264, in an mp4 file format
Old 07-15-2013, 06:26 PM
Exclamation Re: Video Editing Bug
Using H.264 is not advised. It is a supported codec, though it should be on the "use at your own risk" list, as the decode process is very CPU intensive and it's inter-frame nature makes it susceptible to odd behavior.
Old 07-16-2013, 07:31 AM
Thanks for the answer...I suspect that is mostly the problem... but my point is that this video file works differently in PT10 than it does in PT11. I can understand the file not working well in both, but can't understand why it works perfectly in one but not the other...
Old 07-16-2013, 11:55 AM
Arrow Re: Video Editing Bug
It must be a difference with the new Avid video engine in PT11. Whether that difference is on purpose or a bug I cannot say.
Old 07-16-2013, 09:28 PM
Again... Thanks.
I mainly wanted to let someone know of this behavior.
If this is a bug, it would be nice to have it fixed.
Old 07-17-2013, 10:27 AM
I brought this to the attention of the super-moderators.
Editing Video in PT, handling Video TC thierryd Post - Surround - Video 4 11-10-2013 03:24 PM
video editing 372cat Pro Tools 9 3 12-14-2010 07:25 AM
Video Editing in 7.3 Kenny Gioia Pro Tools TDM Systems (Mac) 29 03-11-2007 06:49 PM
Editing Video with PT 7.2 DaveSB Post - Surround - Video 4 07-28-2006 10:15 AM
Video Editing GtrDude 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 11-19-2003 08:28 PM
