OS X 10.2.3 wipes out authorizations on the OS 9 Drive???
I just upgraded my OS X to 10.2.3 - everything went fine.
But when I started up in 9.2 to use ProTools (MIX3) all my plugs were un-authorized! Both systems reside on an unpartitioned Hard Drive. I've been able to switch back and forth and use ProTools in OS 9.2 with no problems until this 10.2.3 upgrade. Anyone else have this problem? Or know WHY this happened?
2019 Mac Pro 7,1 192 GB RAM Catalina OS 10.15.7 PT Ultimate, or whatever 2022.6 is called now HDX 2 w MTRX, Dadman 9.1.4 Dolby Atmos over Dante to external RMU |
Re: OS X 10.2.3 wipes out authorizations on the OS 9 Drive???
On this website, go to Support>Compatibility>Pro Tools|24 MIX for Mac OS>Additional Computer Requirements: System Software.
Under Known Incompatibilities, it states: "...you should not install OS X on the same partition or hard drive with Mac OS 9.x that you use as your startup drive for Pro Tools on pre-Quicksilver G4 models." I would go further than this and say that you should do this on any Mac on which you have Pro Tools installed. Steve |
So that's the problem. The solution?
Complete re-install?
Try "Repair Disc Permissions" from the Hard disc Utility when your in OSX.
Tim Reisig Main System: Pro Tools Ultimate 23.12, HD Native TB, HD OMNI, S3/Artist Transport/Eucontrol 22.20, Apogee Rosetta 800 w/XHD card, Avid 96 I/O Mac OS 13.2.1, 2018 Mac Mini 3Ghz i5, 32Gig RAM System 2: Pro Tools 23.9 (no Hardware), Mac OS 13.2.1, MBP (Macbook Air M2, 2022 24Gig Ram) |
It happened to me too!
Two different partitions! :9.2.2 on one, 9.2.2 and OSX(10.2, Jaguar) on the other. Even after repairing permissions! This is a maintenance routine for OSX only. I had to re-link authorizations. Fine after that [img]images/icons/frown.gif[/img] I guess that Apple is maybe not aware of this or don't want to put money on this, because this problem exists since 10,1. [img]images/icons/confused.gif[/img] |
Call us here in Tech Support and we can walk you through some things. Steve |
Jeff thanks for the heads up on this one!
I had no idea this could happen even with seperate partitions. This will sure keep osX from being all it can be! I have os 9.2.1 and Jag on different partitions do you guys know if this would still be a problem? I'll have to wait until the end of the Month to use osX again, to much going on for this hassle! thanks! daniel |
My advice would to install a seperate hard drive into your system and use that as a deicated OS 9.2.2 drive. You've already dropped a few grand on Pro Tools, an extra $70-$80 at a local computer store will save a bunch of headaches.
Bryan Jackson Independent Audio Systems Engineer Burbank,CA / Las Vegas, NV |
Is this the way that paying customers should be treated? [img]images/icons/frown.gif[/img]
HD ADR wipes generator | puffin | Post - Surround - Video | 13 | 06-04-2018 10:14 AM |
PT 7.4 warning: Interlock authorizations loss/ drive names | neilshelter | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-12-2008 12:59 PM |
Backing-up system drive not losing authorizations | mixaudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-21-2004 11:08 AM |
Authorizations & replacing failed drive? | Mount Royal | Pro Tools TDM Systems (Mac) | 1 | 01-09-2001 07:09 AM |
Authorizations: Installing diskette drive from 8500 in G4MP | Mauro371 | Pro Tools TDM Systems (Mac) | 0 | 09-07-2000 02:11 PM |
