Old 01-12-2010, 11:03 AM
starburst starburst is offline
Default 888/24 S/PDIF could not be made active? Help!
Hi guys,
I'm about to start a project transferring tapes from an old Revox A77 reel to reel machine.
So I connected the A77 to my Yamaha digital mixer which has S/PDIF i/o. Out from their to the 888/24 S/PDIF in.
I'm using pro tools 6.4 on a G4 Quicksilver. I create a session with two tracks (L & R) but when try to change the input on the pro tools channel it says:
The input could not be made active because the input path is currently un available.
What does that mean? What shall I do?
Old 01-12-2010, 11:15 AM
soundboy35 soundboy35 is offline
Default Re: 888/24 S/PDIF could not be made active? Help!
Check your I/O setup and make sure you have S/PDIF enabled for the particular input.
MacBook Pro 15in, 2.3gHz,i7
PT 2021.x
PT12.8.x
Old 01-12-2010, 12:01 PM
Thanks, that seems to have got me sorted, kinda. I have two 888/24's can't get the first one to work with S/PDIF but the 2nd one (slave) is working.
Now, what about word clock? At present I have the two 888/24 set as master and slave. Should I connect the Yamaha mixer as well and what should be master/slave? I've come from LE so word clock is all a bit new to me.
Old 01-12-2010, 02:43 PM
I would try using both the Yamaha as Word Clock master, and slave the 2 888's off of that, as well as having the 888's (1 master, 1 slave) and off to the Yamaha.
Make sure you are syncing to word clock in the Hardware setup, and that everything is set to 44.1 or 48k
PT 2021.x
PT12.8.x
the output could not be made active because the output path is currently made inactiv rosebartu Pro Tools M-Powered (Mac) 4 03-21-2018 12:28 PM
Send could not be made active, not enough DSP crizdee Pro Tools TDM Systems (Mac) 10 10-01-2010 02:17 PM
Plug ins could not be made active because recurces are not available Maddawg383 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-21-2010 11:36 AM
One or more plug-ins could not be made active because there cc1 Pro Tools TDM Systems (Mac) 7 04-30-2010 11:44 AM
Plug-in could not be made active... T-Racks.EQ felipe411 Pro Tools TDM Systems (Mac) 4 08-10-2008 04:49 AM
