Old 11-06-2007, 08:49 PM
cc1 cc1 is offline
Default One or more plug-ins could not be made active because there
is not enough free DSP (error #-7204).
Can this error message be prevented by changing playback engine settings? Right now my settings are:
H/W Buffer: 512 Samples
RTAS Processors: 1 (because I have no RTAS plugins)
CPU Usage Limit: 80%
RTAS Engine: Ignore Errors box is checked
Number of Voices: 120 (5 DSP's)
Sample Rate: 44.1
Delay Compensation: Long (4095 Samples)
DAE Playback Buffer: Level 4
Requires 147 MB of system memory. You currently have 180MB allocated
Greyed Out: Minimize System Memory
Computer: 2 GHz PowerMac G5
Memory: 7GB
Pro Tools: HD2 Accel
Number of plugins desired: 76
Number that show active on tracks: 73
Just 3 plugins are greyed out -I almost made it!
Is another card absolutely necessary?
Thanks in advance for help.... -c
Doesnt matter how I change Number of Voices setting:
(96-6 DSP's, 144-6 DSP's) I still get the exact same scenario
Old 11-07-2007, 05:59 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: One or more plug-ins could not be made active because there
How many DSp voices are being used in the session? can you run the session less then 5 DSP's 120 voices? (can you run on 96 voices 3 dsp's) this would free up the dsp for plugins!!
you could convert some plugins to RTAS
you could use audiosuite to process some TDM plugs then remove them to free up the dsp.
you could bounce some of the tracks to free up some TDM plugs dsp
Chris
Producer, Engineer,
www.ukmastering.com
Old 11-07-2007, 08:42 AM
DigiTechSupt's Avatar
This is very likely caused because the plug-in you're trying to use requires a specific type of chip (there are 3 types on each card) and there are no more of those chips available, even if you free up a chip by reducing number of voices.
Avid Audio Tech Support
Support FAQ
Old 03-26-2009, 02:20 PM
vageli vageli is offline
can i have a document for this issue? can i manage or how can i manage chips with tdm plug ins?error 7204 (not enough dsp) when i try to load tc md3.takes the same chip with tl space and revibe.i use hd 2 with xp
Old 04-02-2009, 07:10 AM
tc reports in compatibility index card that md3 is compatible both on tdm hd and tdm hd accel.so when i load md3 why does not get a free tdm hd chip while all my accel chips are full?i am working on HD 2 Accel.is not only md3.system usage show me that the hd card works only with focusright ,bomb factory,dynamics iii.all other plug-ins take resourses from accel card.can i manage it?thanks and excuse me for bad english.
Old 04-30-2010, 10:54 AM
Thumbs up Re: One or more plug-ins could not be made active because there
got the answer: PRO TOOLS 8 .FREE UNUSED DSP.
but i had a problem with 8.03 update.distortion at playback.uninstall .03 and solved the problem. nice work digidesign with pt8.welldone.sorry about my bad english www.omnidirecord.gr
Old 04-30-2010, 10:55 AM
www.omnidirecord.gr
Old 04-30-2010, 11:44 AM
Sean Russell Sean Russell is offline
You should disable the DSP Cache. It helps a lot.
... but does it help the chorus?
Pro tools m powered "plug-in could not be made active///" Henry199 Pro Tools SE and Essential (Mac) 0 09-05-2010 06:10 PM
Plug ins could not be made active because recurces are not available Maddawg383 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-21-2010 11:36 AM
Plug-in could not be made active... T-Racks.EQ felipe411 Pro Tools TDM Systems (Mac) 4 08-10-2008 04:49 AM
The plug in could not be made active because there is not enough DSP (error #-7204) mmyers Pro Tools TDM Systems (Mac) 14 06-04-2003 06:04 PM
DAE error #7054 - Plug in not made active? OneMadSon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-21-2002 07:49 PM
