Problem bouncing to disk
Hi, this is really starting to bug me; I'm using pro tools m powered 7 with a pc and an m audio 18/14. I've select bounce to disk and the clock starts running and I can hear the music. When the bounce has finished I open the folder I selected for the file to be stored, but it's not there. A few tracks I was mixing down earlier worked fine. This is not the first time this has happened. Anyone any ideas?
Thanks |
Re: Problem bouncing to disk
IM HAVING THE SAME DAMN PROBLEM!!! Have you figured it out yet? Lemmmmmme know! Thanks MUCH!
Are you converting during or after bounce?
If it isn't already, try setting the DAE playback buffer to Level 2 (default).
OSX 10.8 Pro Tools 10 / 11 Sapphire Pro 40 Mac Pro 2.66 GHz Quad-Core Intel Xeon 10 GB 1066 MHz DDR3 |
Me Too!
Everything was fine for a while then I started to notice the file was not there. I reloaded the software, did a file search for it just in case. One guy told me to get rid of the database file in the protools folder and I did that but it only worked one time after that. Is this a 7.0 thing? |
problem with bouncing to disk | mystixboi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-17-2007 03:13 PM |
Problem Bouncing To Disk | Stixntrixx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-29-2006 04:08 AM |
Problem bouncing to disk | laguna | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-12-2006 05:39 AM |
problem bouncing to disk | nskillzz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-16-2005 03:02 PM |
bouncing to disk problem... | chal7ds | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-13-2005 07:14 PM |
