Re: Avid control app / EuControl only works with wifi
Since I own Avid controllers (Artist Mix and now S1) I have never connected the controller to the Router. I always connected the controller to the computer as I think this is the way it should be right?
This is a good guide. https://resources.avid.com/SupportFi...rking_2021.pdf I've always had a robust network with all controller and tablets by using a dedicated router/wifi network solely for Eucon. I have my computers etherthent port going to my internet router just for internet and other networked computers. Then I have a secondary ethernet port (via thunderbolt dock) going to the Eucon Router. All controllers are plugged into that router and the tablets connect to that routers wifi signal. I have that network designated in the Eucon Preferences under System Preferences on the Mac. |
So now I have wifi on the MacBook constantly activated, however still a fast internet connection over the USB to ethernet adapter because it is listed first now, and Avid control can connect flawlessly on the tablet via wifi. Works great now for me. Thanks |
Having two network adapters connected to the same router is a big no, no in IT land. This means there are two default router(if not setup manually/correctly) the computer doesn't know what port to use. Why is wifi even on? Also check the EUCON control panel and make sure the ethernet is set as the port to use.
I do not know if there are technical reasons why USB cannot be used with multiple devices, but if there is any way to bring that back, it would be greatly appreciated.
Pro Tools HD Native 2023.12 | HD Omni | iMac Pro 10-Core 3.0 GHZ - 64 GB - 2 TB - Vega 56 | Ventura 13.5 | Sonnet Echo Express SE II for PT HD Native PCIe and UAD 2 Quad PCIe card | Avid Dock and S1 |
Yes they are both in the same network, but the MacBook is already connected to the network via the ethernet connection, so I don't get it why it still needs the MacBooks wifi turnen on. But as öong as it works I'm happy
Can you collect the logs(from the EuControl menu) and post a link to them in a Private Message?
How to get Eucontrol/Avid Control working? | markytorture | Pro Tools | 3 | 09-28-2023 09:02 AM |
iPad battery drain with wifi and Avid Control | Ben Jenssen | Avid S1, S3, Dock and Control App | 12 | 06-05-2022 11:50 AM |
OSX 10.11.6 EuControl 3.7 Fire tablet Avid Control app has updated (no longer works) | davie1 | Pro Tools 12 | 2 | 12-22-2021 06:04 AM |
avid control WIFI | KIKIQIMIX | Avid S1, S3, Dock and Control App | 7 | 12-04-2020 12:20 PM |
Eucontrol wifi kicks off | manfredyoung | macOS | 3 | 07-31-2017 09:23 PM |
