Video Editing Bug
Ok so I realize that PT ISN'T designed to work as a video editor, however it does edit video differently that in PT10. Editing a video clip has very unexpected results. Simply creating an edit in a video clip causes the 2nd clip to not be continuous with the 1st.
No dragging or moving of either clips... just make an edit, and the clip is now not continuous. |
Re: Video Editing Bug
What codec was used for this video?
Jonathan S. Abrams, CEA, CEV, CBNT Apple Certified - Technical Coordinator (v10.5), Support Professional (v10.6 through v10.10) |
H.264, in an mp4 file format
Using H.264 is not advised. It is a supported codec, though it should be on the "use at your own risk" list, as the decode process is very CPU intensive and it's inter-frame nature makes it susceptible to odd behavior.
Thanks for the answer...I suspect that is mostly the problem... but my point is that this video file works differently in PT10 than it does in PT11. I can understand the file not working well in both, but can't understand why it works perfectly in one but not the other...
Last edited by Jeffrey Talbot; 07-16-2013 at 08:26 AM. Reason: trying to be nice |
It must be a difference with the new Avid video engine in PT11. Whether that difference is on purpose or a bug I cannot say.
Again... Thanks.
I mainly wanted to let someone know of this behavior. If this is a bug, it would be nice to have it fixed. |
I brought this to the attention of the super-moderators.
Editing Video in PT, handling Video TC | thierryd | Post - Surround - Video | 4 | 11-10-2013 03:24 PM |
video editing | 372cat | Pro Tools 9 | 3 | 12-14-2010 07:25 AM |
Video Editing in 7.3 | Kenny Gioia | Pro Tools TDM Systems (Mac) | 29 | 03-11-2007 06:49 PM |
Editing Video with PT 7.2 | DaveSB | Post - Surround - Video | 4 | 07-28-2006 10:15 AM |
Video Editing | GtrDude | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 11-19-2003 08:28 PM |
