Old 09-20-2006, 08:10 AM
JSR JSR is offline
Default McDSP / Eventide Plugins Not Passing Audio
Hi All,
I've recently encountered plugins that stop passing audio upon reopening the session. The two culprets seem to be McDSP (mostly Channel G, but also F2 Filterbank), and Eventide, namely the EQ 45. The plugins are inserted on both audio and instrumental tracks. Removing the plugin and re-instantiating it does not fix the problem...the only way I was able to get around this in some cases is the duplicate the track...the duplicated track then passes audio. I called McSDP about this and they said it most likely has to do with my Expansion HD chassis; they said Digi is having them (I assume all plugin companies) make some code changes that specifically deal with how they communicate with Expansion HD. Is anyone else seeing this behavior? It seems to mostly start happening when sessions get pretty full - DSP wise. Is anyone else seeing this, and are they're any other work arounds.
By the way...all the plugs (and all plugs in my system) are 7.x.
Thanks
HD 4 Accel
Expansion HD
Dual 2.5Ghz G5
6 gig RAM
PT 7.2
10.4.7
Old 10-24-2006, 09:03 AM
BDWillis BDWillis is offline
Default Re: McDSP / Eventide Plugins Not Passing Audio
Hello JSR,
I hadn't heard about this bug, but after spending about 7 hours on a mix, closed & re-opened only to have both Channel G AND Filterbank not passing audio. I tried duplicating the track(s) with no success... this is a momentum-killer if ever there was one.
Have you (or anyone else) come up with any more workarounds???! (All plugs 7.x compatible here too, btw.)
Warmest Regards,
Brian
G5 2.5Dual; OS 10.4.6; 4.5gigs RAM; PT 7.2cs1; HD4 Accel/Process; Expansion|HD
Old 10-24-2006, 09:55 AM
JSR JSR is offline
...haven't found everything yet to fix this, it seems to be consistently Channel G and Filterbank. I got so frustrated with a mix yesterday I just bit the bullet and switched all my Channel G's to SSL's - what a pain that was, plus it cost me about four or five extra hours of work. I worked with McDSP to try to find a solution, but they didn't come up with anything. I think the best thing for you to do is call McDSP, ask to speak with Colin, and tell him about this problem (so he doesn't think it's just me).
Okay,I gave up on my 002.My 003 is not passing audio through when using LLM in PT 10 studiostrat macOS 0 01-11-2014 12:15 PM
Plugins TDM (TC, Eventide, Princetone) Juraj Bernáth Buy & Sell 9 08-29-2012 11:46 PM
Eventide Plugins Future ZEUSS Pro Tools TDM Systems (Mac) 3 10-21-2011 10:33 PM
core audio conects , but no audio passing threw audiomania Pro Tools TDM Systems (Mac) 2 08-23-2006 07:41 AM
Eventide plugins D Clarkson Pro Tools TDM Systems (Win) 2 06-21-2003 11:38 AM
