Using a 32gb flash drive for audio drive
Hey Guys,
I am in need of an audio drive for my recording but am on a tight budget. My friend gave me this idea of using a usb flash memory stick as a dedicated audio drive for the project I'm working on, then moving it to a standard external hard drive for storage when not been worked on. My question is will this be fast enough? Also is 32gb big enough for one (or two) project(s)? Thanks in advance K |
I don't think it would work. Protools recommends 7200 rpm speeds... Try it and tell us your results.
Sent from my SGH-T769 using Tapatalk 2 |
Re: Using a 32gb flash drive for audio drive
most Flash drive are slow
now a SSD with a good bridge board in a case should work 32GB big enough, depends on the project. personally probably not and USB, what OS: Mac, not approved XP or vista, not approved W7, approved
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
There are a few newer usb 3.0 flash drives that seem to have pretty impressive specs, but most usb flash drives, especially the cheap ones, are not very fast. Since price seems to be the determining factor, I'd suggest you just buy a hard drive. It might be worth doing the research yourself just to see how the read/write speeds of some of the cheaper usb sticks compare to a 7200 rpm drive, but I think you'll probably find that the hard drive will be cheaper than any usb stick that has similar read/write performance.
- John If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound? |
One of my clients brought me a CD project(10 songs) that were all transferred on USB pendrives, but they were "cleaned up" of all unused audio to minimize the file size). I dragged the session folders to my audio drive and went to work on them(but I would also be reluctant to try recording to a pendrive). Honestly, buy one(they are so handy to have anyway) and try a test session and see what happens You can get an idea about the capacity by checking the size of some average sessions you already have.
Neil |
thanks for the tips guys. i'll do some research and post my results.
K |
can you record audio onto a Sandisk Flash Drive? | bryced87 | macOS | 1 | 12-25-2013 04:58 PM |
Firewire flash drive | :Rob: | Storage Subsystems | 6 | 06-14-2010 10:55 AM |
USB Flash Drive for Audio Storage | Rainyone | Storage Subsystems | 4 | 01-06-2008 08:30 AM |
Flash as portable audio drive? | bluerockgod | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 01-07-2005 07:11 AM |
Firewire flash drive?? | Paul Cavins | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-23-2004 06:08 PM |
