  #21
Old 01-31-2020, 10:37 PM
avernon82 avernon82 is offline
Default Re: Eucon instability
Random quitting
File Type: png Screen Shot 2020-01-31 at 10.33.08 PM.png (83.1 KB, 0 views)
  #22
Old 02-03-2020, 12:56 AM
Clemens Becker Clemens Becker is offline
Short Update from my System.
I had my iPhone connected to my WLAN, since i turned the phones WLAN off, it seems to run stable now
  #23
Old 02-06-2020, 10:25 AM
I updated the FB thread, thought I would update here. I bought a new Tri Band Router, problems fixed.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I think there needs to be some specific technical recommendations for supported routers. I know a specific router was posted in the Eucon manual, but that is not adequate for a number of reasons. People will want to know if the current router they have is compatible, people may want to buy a different router for other reasons, and people may want to buy a cheaper router, which is what I did. I was able to save $100 going with my router vs the one recommended. Now I have extra money to buy more sound effects
  #24
Old 02-07-2020, 09:48 AM
EddieJones's Avatar
Originally Posted by avernon82 View Post
I think there needs to be some specific technical recommendations for supported routers. I know a specific router was posted in the Eucon manual, but that is not adequate for a number of reasons. People will want to know if the current router they have is compatible, people may want to buy a different router for other reasons, and people may want to buy a cheaper router, which is what I did. I was able to save $100 going with my router vs the one recommended.)
The problem is there are 100's of routers and they change every 6 months. Not only that 2 routers priced the same can perform very different. Sometime a particular router has default settings that are not very good too. So we could recommend a router that is a particular type and even has the same chipset as others but find similar ones perform very differently. The reason the Tri Band all bells and whistles one works great, is that its overkill. But if you have already spend a couple thousand or more on your setup, and use it for work then spending $250 on something like this to guarantee it all works together isn't that much.
  #25
Old 02-07-2020, 11:13 AM
basehead617 basehead617 is offline
You shouldn't need a specific router for a protocol to work. If you do there's a problem with the protocol, not the router.
  #26
Old 02-07-2020, 12:11 PM
EddieJones's Avatar
Correct, but you do need one that matches the performance needed by said protocol. All routers support tcp and udp which Eucon uses but some are dogs when it comes to throughput.
It's like saying you don't need a fast Mac to run Pro Tools... But you do if you want large sessions and snappy performance.
Sent from my HMA-L29 using Tapatalk
  #27
Old 02-07-2020, 01:58 PM
are router's really bad at accurately posting their throughput specs? Just not sure why there couldn't be minimum spec requirements for routers same as computers.
  #28
Old 02-14-2020, 05:56 PM
ok, turns out problem NOT FIXED. Control app keeps disconnecting and re-connecting
I'm getting really frustrated. I've spent hours trying to get this thing stable. I feel like it shouldn't be this hard
  #29
Old 02-15-2020, 05:20 PM
I have the Fire HD10s currently turned off, just the iPad is on, and it's disconnecting and reconnecting. It did not do this before the major rebuild of the app
  #30
Old 02-16-2020, 03:07 AM
bartosz idzi bartosz idzi is offline
Can you connect the Fire 10 to the ethernet via cable, just like the ipad or iphone?
Mac Pro 2 x X5690 3.46Ghz - 64 Gb RAM - SSD 256 Gb - SSD 1TB - OS 10.14.6 - Metric Halo 2882 + Lucid 88192 - Pro Tools Ultimate 2020.11
Instability Issue munchman Eleven Rack 5 01-29-2018 03:00 PM
SSD 4 and instability nozzles macOS 2 01-23-2012 07:28 AM
Instability of 7.3 midi sordino 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-13-2007 05:35 AM
General instability in PT7, looking for help. deafguy Pro Tools TDM Systems (Mac) 12 04-30-2006 11:02 AM
Bluetooth and Instability? Mount Royal Pro Tools TDM Systems (Mac) 1 09-09-2005 05:14 AM
