Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 03-15-2015, 01:37 PM
Audity34 Audity34 is offline
Default MP9 Playback issue
Hey Guys,
I have pro tools MP9, I used to use it all the time, but I stopped for a bit.
Unfortunately as I have started trying to use it again I'm getting a very strange 8 bit computer noise on all my playback. (Almost like an old dial up connection) Even stranger this issue does not effect the actual recording, which is great! The problem is playback is very difficult to listen to and very annoying, as you can imagine.
I have uninstalled pro tools every way possible and reinstalled several times with no luck. I have also tried uninstalling drivers and using the different versions available, but again no luck. If anyone has had this problem or has any ideas I would greatly appreciate it!. Thanks in advance.
Best,
Old 03-15-2015, 01:44 PM
Top Jimmy's Avatar
Default Re: MP9 Playback issue
You don't mention what interface you are using, but one solution for this kind of problem is to use balanced cables from your interface to your monitors.
James Cadwallader
Old 03-15-2015, 02:06 PM
I am using the m-audio fast track pro. Its direct USB, with headphones directly plugged in, no monitors.
Old 03-15-2015, 03:00 PM
Top Jimmy's Avatar
Hmmm, that is a problem. Does it do the same thing if you use the interface with other apps or for Mac sounds?
Does it do it when used with a different computer?
James Cadwallader
Old 03-15-2015, 03:39 PM
Thanks for your quick reply, I appreciate it!
Unfortunately, yes to all of the above.
I spoke with a few guitar center techs that are having the same problem, but theirs goes away when they un-plug(shut-down) the fast track pro and turn it back on. Mine was able to do this as well a few months ago, but now it always has the playback issue.
thanks,
Old 03-15-2015, 10:16 PM
Top Jimmy's Avatar
I've noticed this happening on a laptop with the power adapter plugged in. Unplugging it made the sound go away. Other than that I would suggest trying a different USB cable and/or port. Also make sure you are using the appropriate driver for your software and OS: http://avid.force.com/pkb/articles/e...ck-Pro-Drivers
James Cadwallader
Playback issue Wsigmund Windows 0 11-23-2012 06:57 PM
PlayBack Issue... TheDot 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-07-2010 08:18 PM
Playback issue sstrazis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-31-2010 10:56 PM
Playback issue Andmoore1230 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-29-2008 03:16 PM
Playback Issue vsideproductions Tips & Tricks 1 08-05-2006 07:19 PM
