Device manager exclamation, code 10, is this normal?
I looked in device manager and windows shows an exclamation mark next to the m box.
Windows states that the 'driver is enabled and functioning properly' but also states that 'This device cannot start (code 10)' I think this is possibly new since loading .0.4 upgrade any ideas as to how to fix this? thanks.
Shuttle PC, XP Home SP 3, Core 2 duo 3.16 GHz, 4gb PC6400, 500gb SATA 3G HD, Mbox2 pro., Pro Tools 8. |
Re: Device manager exclamation, code 10, is this normal?
ive seen this before and it usually means a driver issue.
i would uninstall pro tools, uninstall the mbox drivers, reinstall pro tools (DO NOT plug in the mbox when it says "plug in your hardware" then install the cs2 update. STILL dont plug in the mbox. After you reboot, plug it in and Windows should find it. Since youre using the mbox2pro, are you using the included power supply unit? if youre plugging into a regular FW400 port (same plugs on both ends) you should not use the PSU.
i7-860 / 12GB Kingston / Intel DP55WB / 500GB Barracuda / 1TB Deskstar W7x64 Focusrite Saffire Pro 40 / Pro Tools 9.0.3 Mics, Guitars, Amps, Basses, Drums, Keys http://overtheeffect.bandcamp.com |
Specifically, a code 10 refers to an IRQ conflict, which can be caused by driver installation or compatibility issues. Try different USB ports. Downgrade to 8.0.3cs2 in the mean time.
Nick
Core i7 920 OC'ed @ 4.0 GHz (200 X 20) 12 GB Patriot Viper Extreme Asus P6T OCZ Agility 64 GB SSD Hitachi 1TB 32 MB HDD WD Caviar Black 500GB Saphhire HD 5850 3 x 20" monitors Eleven Rack w/ ERXP Fender Super Champ XD Marshall JCM2000 DSL100 Silver Edition W/ Silver Jubilee Cabinet |
003 Drivers not showing up in Device Manager | zedhed | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 10-25-2014 03:46 PM |
Mbox2 Can only have 1 driver in device manager | hijinxbassist | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-13-2012 11:52 AM |
no driver in device manager | tommikks | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 03-30-2012 12:53 PM |
normal behavior for task manager? | wade12 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-08-2009 05:07 PM |
WinXP: No mix farm in device manager. please help | musicmixer04 | Pro Tools TDM Systems (Win) | 0 | 01-02-2009 05:04 PM |
