Tweaking Windows XP and Protools
I think this would be a good over all discussion for All of us since we have allot of deffrent levels of PT,Windows OS,and hardware users in the forum.
what have you done to Tweek the performance of Windows XP, such as services disabeled or removed to strip down XP to the bare bones for operation, and what are your setups in PT, sample rate during record and/or play back, cpu usage set. I think most everyone know what the manual states about things you need to set under XP for Operation in PTLE. This might help all of us 001,002,002r, Mbox users on some of these issues we have. Also comments don't have to be limited to Windows XP, 98 an ME should be included as well Now if we can only get Digi to write PTLE for Linux........Please!!!!!!......Worth a try Ect.Ect.
Running Optiplex GX270 P4 2.8ghz 2gig of ram,40 gig system HD,80 gig PT session firewire HD, 128MB nVidia, GeForce FX5200, VGA/DVI adapter,Digi002R |
Re: Tweaking Windows XP and Protools
The best way to run Pro Tools IMO is not to tweak the Operating System.. except for the very few instructions given in the AnswerBase and the Getting Started Guide.
Basically the Appearance settings and the paging file size if you have 1 Gig or more of RAM.. leave everything else alone. Rail
That was posting on another topic....I used the musicxp.com tips and what would take about 20-30 seconds to import audio into PT now takes 2-4 seconds.
| AMD 64 3800+ | 2.5GB RAM | 200GB SATA | 80GB FW | 256MB Video | Dual 19" LCDs | XP SP2 | PTLE 7.0cs4 | |
Why would you say that given that there are so many things (services) that start running by default at first install that are really not needed.
Print Spooler is a good example unless you have a printer on your PT machine why should you not stop this process. and to take it even furthur , why would you put a printer on your PT workstation?
Hi!
As Rail has said, tweaking should be done with extreme caution. I cannot count the number of times I have hit the DUC, only to see multitudes of people having problems, most of which *may* be due to either excessive tweaking, not using proper components, or simply not RTFM. Yes, certain tweaks may beneift one person, but might not another. As soon as I find time, I will be creating a set of pages on my site giving advice, tips, tricks, etc on my site, including some all important things like HOW to do tweaks (yes Virginia, there is a right and wrong way ), as well as links to various sources of info that so many seem to miss. 'Til then, if one wants to tweak, do so ONE AT A TIME please! Live with that single tweak for a bit (day or more). Use Ghost, or simply leave System Restore on for the C: drive ONLY (this works fine despite what DIgi recommends), and create a Restore Point prior to each tweak (can always delete the restore point later to conserve space). As an example, I have very few tweaks done on my system, and gained performance with 6.4 (very slight; one Aux with plugs inserted), while others have had problems, including loss of performance. As always, YMMV
nikki k Eagles may soar, but weasels don't get sucked into jet engines. On the other hand, you have different fingers. |
Has anyone tried the regedit tweak suggested in MusicXP.net where you turn off last access update for NTFS? I've tried it, but can't really see any difference.
In this thread Rail has not said to tweek with extream caution?
and as I have stated, why would you leave a service running (such as Print spoller) that you may not use, I can't answer for anyone else but my system is dedicated to PTLE and PTLE only, I do have some other software on there that pertains to Editing like Sound Forge 7.0. but this is for recording only, I think anyone would be crazy to think that they can run PTLE, be on the internet, do there Word processing,,general computer stuff on the same machine (not that you can't) But I look at it as not a PC but as part of the PT system, and as so I want to stop all services and or processes that don't need to be there, it just wastes resources. also if you look at my post and read it , I am asking people what they did, that helped them, not that it will apply to me or whoever, but lets get a thread going of things that users Have done, if me or someone else wants to try them and see if they help then good , if not, at least there listed and they might just help someone. Helping others out is what this is all about, a few people here seem to think that anytime a user has a problem it is something they did or didn't do, or the Big one "Using the wrong Hardware", Also I never use ghost, have in the past have seen it have issues as well, I backup all my data to a DAT tape, I use hp Surestore Backup drive and software. Also Ask any IS windows geru and they will tell you that system restore uses allot of resources. I have used it as well here in my work place, it's not very reliable. or it is bacause I try to run Windows XP on the Compaq laptop that it came with?
Yes.....I have done the NTFS tweak....I am thinking that is why the file access and importing new audio has greatly improved.
Where did you go Rail?
this one is for you and Nikki-K, since you two esp. Rail say I am not using compatable Hardware, I would recommending both of you go back and read the compatability list, I just did, funny thing is there is no mention on specific Desktops, just Laptops recommended processors are the Intel P4 , thats what is in mine, I865 Chipset....hey I have that too, no mention of Bios, windows XP it needs to be SP1, I am right there., It recommends Nvinda NForce for the AMD processors nothing said for the P4, I am using the Nivinda GeForce could be my problem but doubt it, now some things that is does say is that USB has to be enabeled if avaliable, I have it but I disabeled it, I don't use USB for anything, Hey maybe thats it Hyper threading disabeled....did that day one. so did I miss anything??? another thing I do find interesting, is that in the users manual and even the David Franz book I have it says if you set processor use to 99% on a dual processor system that PT will use one processor for Protools, Now on the compatability list it says that Dual Processor systems have not been tested.....seems like they say one thing and then another? Now Prove to me I am mistaken, if I am, so be it, I will have at least learned something, and that is always a good thing.
What firewire card are you using?
Tweaking windows 7 | richardmaxty | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 01-19-2010 04:33 PM |
Definite Guide to Windows XP Tweaking for Audio | GordonFreeman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 45 | 11-18-2008 09:33 PM |
tweaking the windows keyboard | webstereo | Pro Tools TDM Systems (Win) | 5 | 04-03-2007 09:28 PM |
Tweaking xp for protools | djkiller | Tips & Tricks | 2 | 03-31-2005 09:10 PM |
xp tweaking | pauleddy2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-03-2002 08:49 AM |
