Old 11-14-2015, 01:27 AM
tonwurm's Avatar
tonwurm tonwurm is offline
Default HEAT license included in PT12HD also working in PT10HD ?
If upgrading from PT10HD to PT12HD, which includes heat, will heat then work with PT10HD and my tdm system, too ?
thanks in advance
Mac Pro 2010: PT10 HD3 on Mavericks, PT12 Ultimate 2020.3 on High Sierra, Logic X, DP 7, VEPro
MacBook Pro: Logic X, Mainstage
Old 11-14-2015, 01:53 AM
VRW VRW is offline
Default Re: HEAT in PT12HD also working in PT10HD ?
thanks in advance
You will have to buy a HEAT license anyway to get it to work even on your PT12 system. It´s just that it CAN
be enabled in PT12 Native for the first time as it never has been possible to use HEAT with Native PT before.
http://www.ebay.de/itm/AVID-Digidesi...EAAOSwjVVVoA0N
http://www.ebay.de/itm/Avid-HEAT-Dig..._N-NbHkueaPhNQ
https://www.avid.com/de/products/HEAT
If you have the license on your iLok you however will be able to use it with all your systems, PT10HD (with your cards)
and PT12 Native.
The best of success to you.
Old 11-14-2015, 01:56 AM
tonwurm's Avatar
Default Re: HEAT license included in PT12HD also working in PT10HD ?
okay ... thanks !
Stig Eliassen's Avatar
thanks in advance
Yes. Natively you need 12.1 or higher.
Old 11-14-2015, 02:12 AM
tonwurm's Avatar
thanks for the info
Installlng PT12HD dwaynedelario Pro Tools HDX & HD Native Systems (Mac) 1 11-03-2015 05:52 PM
Upgrading to PT12HD...now what YYR123 Pro Tools 12 4 09-19-2015 06:32 PM
Does comping to a Heat enabled track print the Heat? joshdrucker macOS 0 03-12-2014 10:17 PM
Mp3 bounce not working in PT10HD Boe Larsen Pro Tools HDX & HD Native Systems (Mac) 7 08-31-2013 04:36 PM
PT10HD and QuickPunch not working...... Bushpig macOS 0 11-21-2011 07:55 AM
