Old 12-15-2003, 11:01 AM
Gio Mix Gio Mix is offline
Default Protools quits with no warning
Hi gang,
I've got one PTHD2 Accel that likes to quit for no reason.
OSX does not even realize it quits (no message like the app....quit unexpectedly...bla,bla)
Its only doing it on this rig. the other non accel HD2 and running 6.1 on a similar machine is totally solid.
Any tips?
6.2.2 on a G4 867 1024RAM
2x Glyph Firewire drives
Waves Gold TDM V4
Focusrite d2-d3
Virus indigo
Ciao
Gio
Old 12-15-2003, 12:43 PM
Studiomeijer Studiomeijer is offline
Default Re: Protools quits with no warning
Hello Gio. I've had about the same problems on my new HD set. After uninstalling the Logitech Control Centre for my wireless Mouse, the problems were gone. Try things like this.
Old 12-15-2003, 12:56 PM
Thanks for the tip,
I'll go turning things on and off and see what works.
Ciao
Gio
Old 12-18-2003, 04:06 AM
Eduardo Apolonia Eduardo Apolonia is offline
Try to move the Sony EQ plug (if you have it) from the plugins folder to the unused plugins folder and see if it works ok (but without the Sony EQ plugin), if it works ok ask for the updated version for panther to sony support and install it.
Mine was crashing like that and since I installed the new version of the Sony EQ it has only occasional crashes when it is loading PT.
Have to figure it out where is it from.
Maybe the it is the Logitech Control as previously suggested.
Old 12-18-2003, 10:16 AM
TLarvenz TLarvenz is offline
I had the same problem. Upgrading to Panther, if you're not already there, seemed to fix almost all my weird quits. Sometimes it still takes a few times to get it to actually start up when you install a new plug-in, but once it loads, you should be good from there. Good luck!
Tracey
Tracey
www.melodiousthunk.net
Protools 7.2 warning ! Stjernholm Pro Tools TDM Systems (Mac) 3 08-14-2006 02:15 PM
Help! Protools always quits huarez Pro Tools TDM Systems (Mac) 3 05-16-2006 01:24 PM
Installing the new EQ III quits PT LE w/o warning? yavuzj 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 07-09-2005 05:41 AM
Protools Quits with new G5 aprim 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-12-2004 08:28 AM
ProTools quits, again and again spicyitaliano 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 15 06-27-2003 05:24 PM
