Old 01-07-2021, 04:11 PM
Rick Drevet Rick Drevet is offline
Default 2 Copies - Couldn't merge the changes
I get this notice every time I add a new track or insert a new plugin. New copies do not have track presets or sessions templates:
You now have two copies of a folder
We couldn't merge the changes to "Pro Tools-RIX-STUDIO-2" so we created another copy of it.
Probably a set up error but I have not been able to correct it. Any help would be greatly appreciated.
Old 01-08-2021, 02:14 PM
Default Re: 2 Copies - Couldn't merge the changes
Hmmm, I've read this thru 5 times and I have to admit I have no idea what you are asking or describing(so maybe I'm not the only one). Also, its nearly impossible to offer any advice with absolutely zero details on your setup. Look in the top dark area for a link named Help Us Help You. Have a good read and come back with full details on your setup(its impossible to give too much info)
Old 01-08-2021, 04:13 PM
The Weed's Avatar
The Weed The Weed is offline
You're not alone. Just adding a track does not create a new template or track preset nor does adding a plug-in to an insert, so not sure what the ask is here - or why a new folder would be created. Maybe if the OP, in addition to adding more info per the "Help Us Help You" link, gave a detailed description of what he's actually doing and how might give us a clue.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 01-08-2021, 04:52 PM
Ben Jenssen's Avatar
This is a "robot".
A computer generated post.
One might say a troll.
So robotroll,..
It's happening more and more.
Couldn't determine 4CC ID! bedermanbeder Pro Tools M-Powered (Win) 0 07-16-2010 06:26 PM
Couldn't help smiling a little ;) AdHawk Virtual Instruments 2 03-17-2010 03:14 PM
I JUST COULDN"T RESIST. DUC should have a "Best Of..." OddsAre 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-02-2008 12:46 PM
If you couldn't use PT jjhuntfox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 02-27-2005 03:09 PM
any reason 4.3 couldn't run on an ibook? Gary Stadler Tips & Tricks 0 02-06-2000 09:07 PM
