Tiger and PT7
Hi all,
I just picked up the PTLE 7 upgrade (so that I could get the two free plugs before time expired) I am still running Panther (10.3.4) and PTLE 6.4 on my 1Ghz, 12" PowerBook. Before I do the double upgrade (7 & Tiger), is there anything I should be wary of? Should I install Tiger, run that for a few days, then install PT7, or should it be somewhat problem free - jump with both feet? Also, which version(s) of Tiger play nicely with PT7 and PowerBook? My specs are in my signature. Just looking for some handholding!!! Thanks a head of time!!! Geoff
12" PB 1Ghz, 512 RAM, Panther 002R PTLE 7.1 60 Gig Maxtor 7200, Oxford 911 FW/USB2 box |
Re: Tiger and PT7
I was in a similar situation with 10.3.9 and PTLE 6.7. I jumped in with both feet to 10.4.3 and PTLE7, and have hardly a bruise to show for it. It was a lot more stressful than it ended up needing to be (if that makes sense...).
Here are a couple of pointers: 1. you'll need to upgrade your PTLE Digirack plugins (and BF plugins) after you install v7, and you'll probably need to upgrade several of your 3rd party plugins if you have any (such as Waves, Ivory, and a few others). You'll just need to check the manufacturer's web site for compatibility with PTLE v7 to see. The old plugins still seemed to work, they just weren't optimized for the dual-processor capabilities of v7. 2. Make sure your admin account works prior to starting the upgrade to Tiger. 3. Back up any really important emails - I seemed to have lost a bunch of older ones in Panther Mail the header was still there, but the body of the email disappeared. That seemed to be the only reall "problem". I don't like the Tiger email program as well, but that's a minor niggle since I don't use my Mac for general email, only for Mac-specific emails such as Digidelivery. 4. Definitely do the Tiger upgrade first. It takes about 45 minutes but is pretty much click and let it run after the first few screens. 5. I believe I had to download a new version of Jam 6 (or Toast - don't remember). The good news is that CoreAudio seems to work with just about everything: iTunes, Jam, Toast, GarageBand, Reason, etc. The basic system was up and running about 2 hours after I inserted the Tiger boot disk - not too bad.
Larry PT 2021; MacBookPro M1; 16GB; Spectrasonics; Native Instruments, Toontrack, Waves...too many plugins. |
Re: Tiger and PT7
Sounds good!
I don't have much for after market plugs, so I should be ok. No dual processor on the PowerBook, also, I only use a Yahoo e-mail account on that machine, so another plus for me. Two hours is not too bad. Probably jump next weekend. I appreciate the response!!!
10.4.8 (Tiger) Security Update 2009-005 (Tiger Intel) Help | Brushfire | Pro Tools TDM Systems (Mac) | 1 | 11-25-2009 09:16 PM |
What Mac can I buy that will run Tiger? | cakes | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-17-2008 05:22 PM |
001 on Tiger | MrMaster | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-29-2005 10:27 PM |
proper panther to tiger with clean tiger install | doug_hti | Pro Tools TDM Systems (Mac) | 21 | 07-10-2005 05:00 PM |
Tech Question---M-box and tiger TDM & tiger | Kawi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-17-2005 03:31 PM |
