Old 11-22-2009, 05:50 PM
Reinaldes Reinaldes is offline
Default session "freezes" for a few seconds when I hit the record button
First of all, pardon my English.
My problem is, when I hit the record button, pro tools "freezes" for a few seconds and only after that pause it starts recording. It doesn't happen when I'm editing just when I start recording, everything stops for a few seconds and it's really annoying. I've changed the buffer size and it still happens, it seems it's not a CPU issue. And I've already cleaned databases and preferences.
Any idea?
Thanks!
Miguel Ferreira
Old 11-22-2009, 06:28 PM
scottedog scottedog is offline
Default Re: session "freezes" for a few seconds when I hit the record button
What version of Protools do you have? The pause/play issue was resolved in v8.0.1 if this is your problem. If not we need more specs.
Your english is actually pretty good.
Scott.
ScottedogStudios on ReverbNation
Old 11-23-2009, 02:39 AM
elicious elicious is offline
you might have "count off" selected-
try looking at your transport window.
if that's not it,
check the pref that allocates disk recording space
(under the operations tab)
if it says "use all available space" or something like that,
change it to a smaller number
e.g. just over the length of the song.
b.o.l.
e
ihatetyping
Old 11-23-2009, 08:41 AM
Thank you guys!
It was indeed the record allocation, I changed it to a smaller number and it worked out.
Old 11-23-2009, 12:29 PM
rqstudio rqstudio is offline
With all the new versions installed this snake has jumped up to bite me again, several times, in larger sessions...
Old 11-23-2009, 12:53 PM
TOM@METRO's Avatar
How much RAM is allocated to PT in task manager when this happens?
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2019.12 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 11-23-2009, 08:26 PM
I'm not sure Tom, it only happened a couple times under pressure, I'm probably not giving PT enough time to complete a task or something. But it was supposed to have been fixed in V8 and as I said has reared its ugly head again.
PT11 - Error "Session must be on an audio record volume" gondor1976 Pro Tools 11 11 12-02-2013 04:16 PM
Volumes set to "Transfer" only / Playback / Record...HELP! Can't open session dudebrotherdudebro Pro Tools M-Powered (Win) 2 07-05-2013 05:21 PM
Volumes set to "Transfer" only / Playback / Record...HELP! Can't open session Tulipbaroo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-06-2011 06:54 PM
Pro Tools error message "Session must be an audio record volume" DeejayMaurice 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 09-10-2011 07:42 AM
What does "PNG" letters mean inside red record button? bookerfatz2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 04-19-2009 09:15 AM
