Old 04-27-2004, 05:55 PM
JBang'em JBang'em is offline
Default Help! I don\'t wan\'t to lose my songs!!!!
Hello. At one point i was working on music every day...Until after two sessons that I saved and closed out, I was no longer able to get back into them. When I double click on the icons, it says: "Microsoft Visual C++ Runtime Library" on the top. Then inside the box is a big "X" with the following beside it: " Buffer overrun detected! Program:...gram files\Digidesign\Pro toolsLE.exe A buffer overrun has been detected which has corrupted the program's internal state. the program cannot safely continue execution and must now be terminated." Then the "OK" box at the bottom. Once "OK" is clicked, another box pops up saying: "ReWireDLL" on the top, and in the box is: "X" Then D:\projects\Rewire\RewireDLL\portable\RewireDLL.cp p(994):Verify Failure"
I don't know what ANY of that stuff means but I have at least two songs thats in there that i cant get to. What do i do??
Old 04-27-2004, 06:00 PM
Bazzle Bazzle is offline
Default Re: Help! I don\'t wan\'t to lose my songs!!!!
First off, don't panic!! I doubt you will lose your songs.You will probably have to reinstall the program.
Bazzle
Old 04-27-2004, 06:08 PM
Thanx for your reply But, do I uninstall first, then reinstall? or just reinstall it? (I know i sound dumb)
Old 04-27-2004, 06:14 PM
You can go to Add/Remove programs and try Repair installation.See if that works.
Bazzle
I wan't to upgrade savaunn Pro Tools SE and Essential (Win) 4 06-11-2016 01:04 PM
uploading songs into Pro Tools from downloaded songs in iTunes? GMP 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-17-2009 09:52 PM
Set up seperate songs from string of songs in one recording Grainbelters 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-30-2008 10:16 PM
I WAN'T Powered plug-ins !!! theom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 34 09-07-2001 08:45 PM
