Old 03-18-2004, 03:31 PM
maskedman72 maskedman72 is offline
Default -9128 errors when using only 4 plug ins,why?
ill start a mix and get "youre using too much cpu" errors after adding just a few plugs. i was using 2 comps,1-4band eq and 1 d-verb. and my system wont play anything until i take ALL the plugs off. can anyone help me?
www.tempermillstudios.com
Old 03-18-2004, 03:56 PM
Cliffy_Boy's Avatar
Cliffy_Boy Cliffy_Boy is offline
Default Re: -9128 errors when using only 4 plug ins,why?
either insert a dither plug-in before the d-verb OR remove the dverb and you will be fine.
Cliff Stendel
-iMac 5K 32g
-PT12. HDX
-HD I/O 8x8x8. -HD Omni -Avid S3
-API 2500 -API 5500 -UA 2-1176 -UA 2-610
-Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96
-Bricasti M7. -Joe Meek channel.
-Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more
-Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12
Old 03-18-2004, 04:54 PM
Yes, that might be caused by the P4 and Dverb 'denormalization' bug. 'Search the DUC' for 'denormalization and you'll see that it's fairly common. (and that the workaround is to use a dither plugin)
Quad 2.5 G5, 4.5G RAM
Old 03-19-2004, 02:20 AM
i had a dither plug before(above)the d-verb when i got the -9128,but not before the 4 band eq. do i need to put a dither before the eq?? how about before the comp?? to insert a plug before another, is it above or below it?
Old 03-21-2004, 06:35 PM
JFrazier JFrazier is offline
my -9128 error kicks in with only ONE plug... Motu's MachFive... and only using one instrument (one midi channel) as well...
finally fought off a -9035... now I'm dealing with a -9128... don't really feel like buying an external MIDI sampler... would like to the the "Mach Five" working...
tried deactivating some of the tracks (audio and aux's) and it played for about 4 more seconds before crashing...
help...?
Jim
800MHz PBook (could be the problem right there... but it shouldn't be)
002R
Pt 6.2.3
Os 10.3.3
Old 03-21-2004, 06:37 PM
Cliffy_Boy's Avatar
Mach 5 is a hog and not well designed for the PC side of life.
Cliff Stendel
-iMac 5K 32g
-PT12. HDX
Old 03-21-2004, 06:50 PM
ooops... I'm posting in PC land...
well, thanks Cliffy, the same can be said for OS X land...
crash, crash, crash, crash, crash...
Old 03-21-2004, 07:31 PM
Telepc Telepc is offline
I had this happen today on a really small session with 4 tracks and 5 total plugins between them, yet things were fine on a larger session with 24 tracks and many more tracks.
The only thing I did different on the small session was try to a plugin automation on the D-Verb. I selected the algorithim to be automated. As soon as I tried to play (and do an automation pass), I got the 9128 error. I turned the D-Verb automation off, but it didn't fix it. Shutting off all my plugins didn't fix the problem.
I restarted PT and everything was fine. I played through my song one time, this time with the system-usage meter up. Everything was fine until the song ended and playback stopped. Suddenly, like 5 seconds later, the CPU meter just jumped to the max.
Definitely a bug. Could it be related to the "denormalization" bug mentioned above?
Digi002-R
14" G4 I-Book 1.33 GHZ, 1.25 Gb RAM.
Seagate 160 Gb ext. firewire HD
ADA-8000
10.3.8 and 6101 / 9128 errors Muzoid Pro Tools 10 3 01-27-2014 05:23 AM
9128 errors jrmintz macOS 2 10-09-2012 07:39 PM
More PTX Buffer Errors: -9128 ronzie macOS 35 03-02-2012 11:52 AM
Moogerfooger AD and RM plug-ins cause -9128 Errors colinmansfield macOS 1 02-12-2012 05:28 AM
9128 errors - please help :( gavp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-29-2011 09:52 PM
