Select next/previous track from button on Dock?
Is there a way to select/attention the next or previous track from a button on the dock, without using the touch screen? Or do you have to give up a touch strip button or use a softkey for that? Thanks.
Re: Select next/previous track from button on Dock?
Hey, Mark! Great to see you on here. Welcome to the DUC!
I programed my Dock to scroll through tracks using the jog wheel which includes the keystrokes for nudging. You could scale it down to two buttons for left/right one track at a time or use this to scroll quickly through a session. 4th post down has the steps for setting it up. Cheers, Chris http://duc.avid.com/showthread.php?p...47#post2533847
• MacPro (4,1 to 5,1) 12 Core 3.46 GHz // 96GB // AJA Kona LHi // OWC Mercury Elite Pro Quad, USB 3.0, eSATA • PT HD|Native 2024.3 on macOS 12.7.4 (OpenCore Patcher 1.4.3 on Crucial SSD) • Avid Dock, iPad 7th gen & EuCon 2023.11 • DADman/Eucon monitoring • BSS (DAN + 100), QSC DCA 1644, JBL 7 Series • MTRX Studio // 7.1.4 www.quesound.com |
New dock solo button lower then mute button | Sean Bombz | Avid S1, S3, Dock and Control App | 14 | 10-12-2017 06:05 AM |
There is a shortcut to select the next or previous track? | cmbourget | Tips & Tricks | 10 | 09-19-2016 03:34 PM |
Shortcut to Select Next/Previous Track | headsup | macOS | 8 | 02-21-2012 01:23 PM |
Can u select the track by using rec/enable button ? | JonLance | Pro Tools 9 | 0 | 08-06-2011 07:32 PM |
"select next/previous track" "rec enable track" key command? | maufau | Pro Tools TDM Systems (Mac) | 6 | 04-22-2008 05:08 PM |
