Old 11-22-2012, 12:45 PM
jamesimm jamesimm is offline
Question HD 8 issues
Okay, running HD 8 on Pci cards in older Pci G5, OSX 10.5.8, and when I go to boot up I get "cannot find audio interface attached to first HD card"
Bought new digilink cable and new flex card to join Core to Accell...Is there possibly an issue there? ie... do you put the flex card in the front slot of the Core and then connect to the Accell card directly above using the back slot? or??
Im using a Roland C7200 V-Mix, DIF AT interface with light pipe connections to the 3 digital in/out of the i92, digilink cable from primary port to Core card...and the cards are in the right order, Core in the lowest numbered slot (1 has video card) #2 accle directly above in slot 3.
HD8 on G5 Pci
Accel and Core cards (Pci)
Digi 192 A/D
DIF-AT with light pipe connections to digital ports of 192
digilink connected to primary port on 192 then core card
What am I missing???
Old 11-23-2012, 02:12 AM
the dude's Avatar
the dude the dude is offline
Default Re: HD 8 issues
10.5.8 on a PPC G5 is only usable with pro tools 8.0 and 8.0.1( not 8.1 )
so if you have anything higher than 8.0.1 installed that is why you have a problem
Leopard
10.5.5
10.5.6
10.5.7
10.5.8
PowerPC Mac
8.0
8.0.1
LINK
Flex Cable goes from Core (B) to Accel (A) but even if you have it reversed it would not cause the IO to not be seen by PT
http://www.studio-techservices.com
าำ
studio.tech@yahoo.comm
Mitch Berger Tech Services
We service ALL Avid products no Problem
HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything
ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around
inquiry using link above
Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear
Old 11-23-2012, 02:18 AM
JFreak's Avatar
JFreak JFreak is offline
Are you sure you have connected the internal ribbon cable correctly? It must go from core card connector "B" to accel card connector "A" which is kind of counter-intuitive but that's how it works.
If the ribbon is backwards, then the system actually considers your accel card being the first card in the system.
Janne
Old 11-23-2012, 07:34 AM
Thanks...thats what I was wondering...Ill check and let you know
Old 11-23-2012, 07:39 AM
Aaahaa....I had a feeling..Ill un install 8.5, down load 8.0...sounds simple but what elese will be affected??? I dont uoze thgis G5 for anything but POT...so im assumoiny my periferald will still be good? like the 192 I/O and the DIF-AT's plug ins and TDM? still okay? or am I headed to that neverendingcirlneverendingcircleneverendingcircle. ..LOL
Old 11-30-2012, 01:55 PM
any suggestions for the removal and installation of OSX 8.0?? I found a new copy just want to make sure I dont kill anything else when I do this...do I have to wipe the 8.5? Or?? THANKS....
Mbox Gain Issues and Protools Issues (Bounce to Disk and Knob/Pot adjustments) Lucky Bastard Getting Started 6 01-16-2014 04:29 PM
No sound - asio driver issues - NTFS issues mitchelljrickey Pro Tools Software (Win) 0 06-21-2012 06:35 PM
ProTools 9.0.5, iLok issues, Digi 003R+ issues zachbot Pro Tools 9 6 10-12-2011 09:19 PM
8.0.4 Issues (Quick Punch & Mute/Solo issues) pauledwards 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-06-2010 10:35 AM
Digital Noise Issues - Clock Source Issues? Gorbies 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-07-2010 02:55 PM
