Mac Pro 3.2G Quad - 8 CPUs
Hey guys,
We bought a new Mac Pro this past July, and for the longest time I'd only be able to select 4 CPU's when running TDM. However, today I was playing around and doing some tests. When I turned off the 192's and ran purely native, I suddenly realized I could now select 8 CPU's in the Playback Engine window. After closing Pro Tools and opening it up in TDM again, the 8 CPU's are now available there as well...is this some kind of a weird bug? It now feels like I got a 2nd computer attached haha. What in the hell? I went for nearly 5 months without figuring this out... Sig |
Re: Mac Pro 3.2G Quad - 8 CPUs
That is bizarre!! if you had of said you only had 4 CPU's i would have said the computer had a hardware fault and nothing to do with pro tools. but you think switching to native suddenly made the 4 CPU's jump into life? well, stranger things have happened, but I've never seen anything like that before. chris
Me neither!! But, it'd been this way since July when we got it...
It must have simply been a bug in software, but I'm glad I looked into it further haha. I'm now able to actually use it!! Thanks, Sig |
there are still only 4 hardware cores , if you have a 1 cpu model.
the cpu s since nehalem (macpro2009)have 4 hardware + 4 "virtual" cores.. the reason you see 8 cores. In fact not double the performance but at least a plus of 20% cpu performance. i have a 2 cpu nehalem and see 16 cores btw.... but there are still only 4 hardware cores and as that you should handle it. the "law" 1 core less then available for PT means here: 6 cores for PT , 2 cores for OS and rest. regards
foley artist , soundeditor |
DIGI 001 only for old CPUs? | bearsound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 15 | 07-18-2011 03:23 AM |
Protools le on two different CPUs | MRED22 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-26-2008 06:27 AM |
HD cards vs CPUs | JonHallur | Pro Tools TDM Systems (Win) | 19 | 01-13-2007 07:41 PM |
Dual cpus | Raggi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-18-2005 01:16 PM |
What about OEM CPUs? | Stone B | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 07-27-2002 12:46 AM |
