Old 11-17-2012, 12:40 PM
Eduardo Apolonia Eduardo Apolonia is offline
Default Thinking of upgrading from HD3 to HD6, what should I be aware of?
I'm thinking of upgrading from HD3 to HD6.
Before everybody tells me that I should go the HDX route (which I'm also considering but I'm walking slowly away of it mainly because of Waves not developing AAX DSP), here are my reasons to be thinking of HD6 and not HDX
Reasons:
- I want to add more I/O and processing power.
- AAX DSP plugins are still not much and Waves won't do AAX DSP, and I use Waves plugins a lot, so the HDX chips won't have much use.
- HD process cards and 2nd chassis are getting very cheap at the moment.
So, what should I be aware of?
I have to buy an expansion chassis, of course.
Which ones are compatible?
Read about some Revision K HD cards problems, but got a bit confused with different info. Could someone enlighten me about the incompatibility problem?
Can I connect 4 Aurora 16s and take advantage of 64 I/O analog + 64 I/O Digital?
I have a Mac Pro 8 Core 2.8 Harpertown
PT 10.2
Thanks in advance :)
Old 11-17-2012, 09:47 PM
studiojimi's Avatar
studiojimi studiojimi is offline
Default Re: Thinking of upgrading from HD3 to HD6, what should I be aware of?
DO IT.
i went from HD4 to HD6 the added power is just what the doctor ordered.
CAZADOR RECORDING
PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2
With GOD as my partner. . . I need to make my plans LARGER.
Old 11-18-2012, 09:50 AM
WernerF WernerF is offline
HD 6 works great here. I am, as well, waiting for more AAX DSP plugins to become available before considering HDX. My workflow does not allow for a mainly RTAS environment. You will need a Magma PE6R4i. That is the newer one which has the single cable to attach to your computer and it has the quiet power supply fan. The older unit sounded like a rocket ship launching.
Old 11-18-2012, 10:29 AM
Thanks guys,
Did any of you have any problems with the cards?
How many I/Os are you using?
Old 11-18-2012, 11:00 AM
JFreak's Avatar
JFreak JFreak is offline
Me too. Waves aside, I have another problem regarding REVERB/DELAY plugins available on the HDX platform. What I've used to use are for example:
- Eventide H3000 Band Delays
- Eventide Reverb
- Lexicon MPX
- Lexicon PCM
- Line6 EchoFarm
- TC DVR2
- TC NonLin2
- TC VSS3
How many of those are available as AAX whenever PT11 comes out? And of those, how many are DSP capable? I fear the reverb/delay offering is going to be Avid-only for some time, which is the #2 reason (after Waves) why I have to keep waiting... Can't switch if my tools (plugins) are taken away from me.
Janne
Old 11-18-2012, 01:27 PM
Originally Posted by Eduardo Apolonia View Post
Thanks guys,
No problem with the cards. Also, I have 32 analog inputs available with two 192's that both have the extra 8 input analog IO cards. Works flawlessly.
Old 11-18-2012, 01:34 PM
Delta Music Belgium's Avatar
Delta Music Belgium Delta Music Belgium is offline
I had problems with a 'revision k' HD Core card with my 6-core Westmere + PE6R4-I + PT HD6 Accel PCI, in the end Avid replaced the card for free.
More info in these posts:
http://duc.avid.com/showpost.php?p=1...&postcount=107
http://duc.avid.com/showpost.php?p=1...&postcount=109
http://duc.avid.com/showpost.php?p=1...&postcount=113
http://duc.avid.com/showpost.php?p=1...&postcount=114
Btw, since then my system is rock solid, see system details below
Marc Schellekens
Delta Music Belgium - Pro Tools | HDX Studio
http://www.deltamusic.be
System 1: Mac Pro (Mid 2012) 3.33 GHz 6-core - 32 GB RAM - OS X 10.13.6 - Magma EB7 - PT HDX3 - PT Ultimate 2018.12 - HD I/O 16x16 - 192 I/O - 192D I/O (x3) - SYNC HD I/O - Apogee Big Ben - Rosetta 200 - Slate RAVEN MTi2 (x3)
System 2: Mac Pro (Mid 2010) 3.33 GHz 6-core - 32 GB RAM - OS X 10.9.5 - Magma PE6R4-I - PT HD 6 Accel PCI - PT HD 10.3.10 - 192D I/O - SYNC I/O
Old 11-18-2012, 09:35 PM
RCN RCN is offline
I have 4 cards, works great...
Fattrackstudio.com Pro Tools 10.2 HD4, Mac Pro, Magma pe6r4-1, Apogee AD16x, Digi 192, Digi 96
Old 11-19-2012, 01:05 PM
Is the P7RB also compatible?
Thanks for the links.
Old 11-19-2012, 01:37 PM
dtmprod dtmprod is offline
I have an HD-6 which is great for mixing. Probably don't need that if you're just recording & editing. And I'm of the opinion that TDM plugins generally sound more robust than the native versions. Some possible exceptions might be those from Brainworx, Softube, UAD.....
For those thinking of upgrading to Mavericks... mrjohn Pro Tools Software (Mac) 3 10-27-2013 04:32 PM
Thinking of upgrading to 8 Shanegrla 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 08-24-2009 04:01 PM
Thinking of upgrading to HD tim carter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 20 11-18-2008 09:45 PM
Thinking of upgrading to Nehalem stryder Pro Tools TDM Systems (Win) 3 10-04-2008 11:25 AM
Thinking of upgrading to HD from LE. Advice? Jumpman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 01-02-2005 03:40 PM
