Old 10-21-2011, 09:06 AM
blairl blairl is offline
Default HDX latency vs. HD Accel
One of the hallmarks of the TDM cards is the ability to track with extremely low latency. I can track live with several plug-ins with musicians in iso booths listening to each other via headphones with no noticeable latency.
Even the newer HD native card does not match the latency specs of the TDM cards.
I am assuming that Avid recognizes that the extreme low latency of the TDM system is something that put them far ahead of all competitors in terms of using the system for tracking, and I hope that the new HDX cards either match or beat the latency specs of the TDM system.
Can someone at Avid confirm that the latency of the HDX card is as good or better than the TDM systems? Can the AAX plug-ins be used in the same way that TDM plug-ins were used (recording with plug-ins enabled with extremely low latency)? Do you have any specific latency specs?
Thanks!
Old 10-21-2011, 09:57 AM
drumster drumster is offline
Default Re: HDX latency vs. HD Accel
I heard on the web chat last night that latency with HDX card at 96K is 0.07 msec. That is, of course, with one of the new Avid interfaces.
Lynx Hilo Thunderbolt
2013 Retina Macbook Pro 2.7 16 GB of RAM
PTHD 11.3.1 OSX 10.10.1
Old 10-24-2011, 04:39 PM
Abomb97 Abomb97 is offline
http://www.avid.com/static/resources...ilyLatency.png
Its actually .7 ms
ProTools 2018
1 x Apollo Quad Firewire
1 x Apogee Duet 2 mac/ios
MacBook Pro (15-inch,2018)
2.9 Ghz Intel Core i9 CPU
32 GB 2400 DDR4 RAM
1TB SSD System Drive
Mac OS High Sierra 10.13.6
Old 10-24-2011, 04:41 PM
Sorry, typed that one in wrong. Thanks for the correction.
Old 10-24-2011, 04:50 PM
digidesigner digidesigner is offline
Question is if the AAX plugins have the same low latency as TDM
Old 10-24-2011, 05:53 PM
Mt.Everest Mt.Everest is offline
Originally Posted by Abomb97 View Post
So thats about 40 samples or so right?
Is that TOTAL latency throughput, as in input-->ADC--->PT--->a track in record routed to 1-2 --> DAC ?
I actually forget what the latency is of current TDM systems. About the same right? As long as Im under 100 samples when tracking, its fine.
Does anyone know off hand the default number for a basic HD1's throughput, in samples, using only a sound source, a track in record, and sent to the output..
Thanks,
MT
PT|HD4 Accel PCIx w Magma Chassis & 192 I/O
PT HD 9.0.5 - Mac Pro 8-Core 2.4Ghz Westmere 10.6.8
PT|HD 9.0.5 - MacMini Core-Duo, 10.6.8 - ProFire 2626
•••DON'T BELIEVE THE HYPE•••
•Use & Trust ø Cancellation!•
Old 10-25-2011, 03:21 AM
James Drake James Drake is offline
It says clearly analogue>analogue latency.
It also says that they tested hdx with hd i/o vs hd accel with 192.
So this is really testing the difference in convertors and i guess that hd and hdx actually have the same latency.
Process Card Question... Accel vs non Accel gsilbers Pro Tools TDM Systems (Mac) 13 05-22-2013 01:51 PM
HD 3 Accel PCIe = 2 Accel Core + 1 HD Accel???? Eduardo Apolonia Pro Tools TDM Systems (Mac) 24 08-04-2007 02:20 PM
Runing Accel plugs on the "Accel PCIe core DaveSB Pro Tools TDM Systems (Mac) 0 12-19-2005 10:25 PM
Latency problem with my HD3 Accel Drive d Pro Tools TDM Systems (Mac) 1 06-19-2005 04:55 PM
HD Process to Accel Exchange vs. Mix to Accel Exch Armando Pro Tools TDM Systems (Mac) 3 05-20-2004 04:18 PM
