omni output question
Hello,
I was wondering if I could run the digital outputs thru the monitor control section and also mirror the output to the analog outputs WITHOUT the monitor control section padding the analog output? I want to send to my Dorrough meters via analog and send to my jbl4328p 5.1 via digital. I obviously cant pad the inputs to the meters. Thanks. |
Re: omni output question
Bumps.
I think you can. In the monitoring tab in I/O Setup, you assign the main CR to Digital, but leave one of the analog stereo pairs out (Say 7-8). You will likely have to do it in the bussing; your stereo bus needs to be a bus that feeds two auxes: One to go to the monitor out (digital) and the other aux to go to the analog output you assign it in the aux's output. See what I'm saying? One stereo bus feeds two auxes, with different output routings.
thanks for the reply.
Im running multichannel meters and speakers so I would need to set the monitors up as the digital outputs 5.1 and double bus (already doing this as I have it now) to the analog outs and the analog outs will not be padded by the level set on the omni? i know the omni can only have 8 outputs but can mirror the outputs if needed. The question (again just to make it clear) is will that second set of outputs be padded via the volume knob on the omni. |
Are you sure the Omni does any kind of mirroring? I don't have the unit, but I've gotten to mess with it and read the manual and I don't find that capability.
I only just got mine days ago so I'm not positive. I know you can mirror stereo out the TRS, not sure about digital double-bussing.
I've read that it will mirror the outputs however maybe its only a stereo pair? Digitech? Can you clear this up please?
Calibrate OMNI interface for 5.1 output? | drguitar | Pro Tools HDX & HD Native Systems (Mac) | 16 | 03-05-2021 05:56 PM |
No sound from OMNI ALT Monitor output! | UnkleMik | Pro Tools HDX & HD Native Systems (Mac) | 4 | 11-18-2013 11:01 AM |
HD OMNI isn't truly 8 output ... | agershon | Pro Tools HDX & HD Native Systems (Mac) | 9 | 06-12-2013 10:00 PM |
Omni distorts on monitor output | sammyfarr | Pro Tools TDM Systems (Mac) | 0 | 04-09-2013 02:17 AM |
HD Omni output levels and PPMs | idris | Post - Surround - Video | 8 | 07-18-2012 03:14 AM |
