Old 10-18-2017, 08:56 AM
moranibus moranibus is offline
Default EuControl 3.7 crashes immediately with PT
Says it all. PT updated to 12.8.2
PT Ultimate, Avid S3, Avid Artist Transport, Pro Tools Control
Old 10-18-2017, 10:18 AM
The Mixing Factory The Mixing Factory is offline
Default Re: EuControl 3.7 crashes immediately with PT
Same here, and same issue with other DAWs...
Old 10-18-2017, 10:59 AM
Actually moranibus, try uninstalling v3.7 and trashing the folder "Euphonix" left in your applications folder (assuming you are on MacOS), install again v3.7 with all other apps closed but peripherals switched on. Open EUC and tick EUcontrol under the "Auto-launch Apps" sub menu, restart the computer (EUC should now open on boot up) and open PT.
This worked for me, I didn't uninstall the old version before installing v3.7, I asume that was the issue and probably provoked a preferences issue...
Old 10-18-2017, 11:30 AM
Thanks, man. No success. Did everything as requested.
Old 10-18-2017, 11:36 AM
Sandborg Sandborg is offline
Thanks The Mixing Factory!
This worked for me, so you saved my day, didn't have to delete the folder from applications, that happened automatically when uninstalling Eucontrol.
Old 10-18-2017, 11:39 AM
hugoleitao hugoleitao is offline
same here...
Old 10-18-2017, 12:21 PM
hmm... all I can suggest then is to trash PT's preferences but that ain't exactly fun... good luck!
Old 10-18-2017, 12:22 PM
cool! glad it worked...
Old 10-18-2017, 02:23 PM
EddieJones's Avatar
We found the issue and it's not to do with the software but the installer. The workaround until we generate a new installer is to simply uninstall 3.7(or3.6) and reinstall it. No need for the Clean EUCON script. If this doesn't work you can manually delete the offending files after uninstalling:
You can do this in the Finder by going to the Go menu and choosing Go To Folder… and type in /usr/local/lib
You should not see libEuCon2.dylib or libEuConDLL.dylib
If you do, delete them, then reinstall.
We are working on the new installer......
Old 10-18-2017, 07:38 PM
Ed Douglas's Avatar
Ed Douglas Ed Douglas is offline
Thanks for this... it was driving me nuts. Turning off "Enable EUCON" in the peripherals dialog prevents the crash but defeats the purpose. Will try clean reinstalling as per your instructions.
Cheers!
E>
Update - All is well now! Thanks again!!
Neotech Concepts
http://www.imdb.com/name/nm0235036/
! sonic gymnastics for the illusionary arts !
2022 Mac Studio Max 64GB / 1TB, macOSX 13.6.6, 2019 i9 MacBook Pro (15,3), macOSX 14.4.1, PT Ulti 2024.3.0, DAR 5.1, MDA Creator1.5, Rx10 Advanced, Ozone 10 Advanced, Kontakt 7, Soundminer v6.1Pro, Spanner 4, PaulXStretch,
EuControl 2023.11.0, Avid Control 2023.11.0, Avid S1, iPad Pros 12.9" gen 3 & gen 4, Apollo 8 Duo, UAD-2 Satellite Quad, Glyph 2TB tb3 NVMe SSD, x2 Glyph 2TB SSDs, x1 Glyph 4TB SSD, OWC tb3 Dock, OWC Thunderbay 8 62TB
Pro Tools crashes immediately Rich Crescenti 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-21-2010 03:44 PM
PT8 M-Powered Crashes Immediately chrisconover Pro Tools M-Powered (Mac) 10 05-31-2009 10:19 PM
ProTools crashes the system immediately amfm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-23-2008 01:48 PM
LE 6.4 crashes immediately with 002R j20056 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-27-2005 06:37 AM
Mac G4 Crashes Immediately...I'm really new to this luapfitz Pro Tools TDM Systems (Mac) 2 09-04-2000 05:40 AM
