PT 11 not seeing my SYNC I/O
Hey guys, just update to 11 (11.3.1) and after setting the initial prefs it's not seeing my sync IO. What's the deal?
Lior HD Native * PT 2018.12 * OS X 10.13.6 * MacPro 12 Core * 2.4GHz 24GB Ram * 2XUAD2 Octo * Waves Platinum * Lexicon PCM Native Bundle * Sound Toys Bundle* AutoTune8 * NI Komplete11 * BFD3 * Synthogy Ivory II* Vienna Ensemble Pro * Spectrasonics * Slate trigger2 *xFer records * Softube * Vienna Ensemble * DMG Expurgate * Massey DRT2 * iPad Air/Avid control * EuCon 18.3.0.217 * |
Re: PT 11 and SYNC
Which Sync Unit are you using? Pic it's the original Sync IO, it won't work with pt11.
It is the sync HD (either blue or grey in colour), you may need to upgrade the firmware - also check that it isn't in 'sync IO compatibility mode', as that will prevent it from working.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command. |
Re: PT 11 and SYNC
It's the blue HD…:
Re: PT 11 and SYNC
That's a Sync IO not a Sync HD. Sync IO won't work with PT 11/12.
iMac Pro - MacOS 10.14.6 --- - Pro Tools U HDN 2019.6 - Avid HD Omni + HD I/O 8x8x8 - C|24 | S3 | Dock |
Re: PT 11 and SYNC
Tried to update the firmware keeps saying:
firmware update aborted: couldn't establish communications with the SYNC. Please power cycle it… blah blah blah. Any thoughts?
Re: PT 11 and SYNC
Screen shot attached:
Re: PT 11 and SYNC
They blue Sync HD says "HD" on the unit. Yours doesn't, so it must be a Sync IO.
Re: PT 11 and SYNC
Does anyone know why they discontinued support for those? (other than wanting to make money...?)
Re: PT 11 and SYNC
Got a SyncHD (blue) feeding a Big ben. Big ben set to accept WC and sends that to (3) 192's WC in. Had it this way for years now with Sync IO. Now with the HD- I set it to internal, 96K, 30FPS (non-drop) and set the 192's to accept WC. It works great. The second I enable the SyncHD in the peripherals menu, it reverts to loop sync and says 96K, but the big ben shows it's getting 70.90
By the time I go into my session @96k the 192's are all messed up. ANYONE?!
Re: PT 11 and SYNC
Seems to be resolved- had to deselect 'enable dub window' Not sure why that was causing all this chaos, but here we are!
Sync Audio - Editor Used Camera Track Only -Waveform Sync? | milosziv | Post - Surround - Video | 7 | 11-30-2011 05:26 AM |
Keeping Laybacks in Sync (delay compensation and Video sync offset) | edit machine | Pro Tools TDM Systems (Mac) | 6 | 11-15-2010 11:33 AM |
Midi Timing Delay Sync Issue: MTC Sync | daysean | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 17 | 01-22-2007 11:48 AM |
Can Mbox sync to midi timecode or smpte sync? | greeneye | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-05-2004 08:47 AM |
Sync Processor's Tremolo to Midi Time Sync via Interface | j_jayzatuc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-01-2000 12:08 AM |
