Old 10-17-2008, 02:03 AM
GTBannah GTBannah is offline
Default Memory Locations/Markers
Can we edit/rename memory locations/marjers "on the fly"?
I'm listening to a project and I press "Enter" to insert a marker at 23|1|00 and I "miss" by about two beats. Can I "double click" or something on the marker and change its properties, in terms of Name, location, etc.?
Even in the Memory alocations dialogue, I only see the beat number if I do it with the project stopped, and time properties set to "None".
Because I don't know how to do it, it's a workflow issue right now.
.... and yes, I RTFMed.
Derrkins
GuyBarTola
PT 2018; Nuendo 8.?; Studio One 3; former Sonar and Sequoia user .... GENELEC 1031A, AVANTONE MIX CUBES (Active); Sibelius 7.0; Dorico; Mac Mini 2.6 GHz Core i7, OS X 10.12.2 Sierra; 16GB RAM; 480 GB System SSD; 1 TB 7200 rpm Audio; 3 TB samples; Roland A-800 Pro controller; GOOD BYE PEE SEA!!
Old 10-17-2008, 04:31 AM
Bill_Urick Bill_Urick is offline
Default Re: Memory Locations/Markers
You can drag the markers to the desired locations.
Old 10-17-2008, 06:07 AM
.... but only when the track has stopped. I want to be able to, in the page with the list of markers, double-click or right click on a marker and change its properties.
Can that be done? MAybe 8.01, or CS 1 ....
Work flow, work flow, ....
Derrkins
GuyBarTola
Old 10-17-2008, 06:59 AM
AlexLakis AlexLakis is offline
You can drag the memory locations while you're playing back, just left click and drag them in the "markers" toolbar at the top. Also, if you have "auto-name memory locations" unchecked in preferences, you can name them as you go along all without stopping playback.
Old 10-17-2008, 07:06 AM
Yeah, got that. Thanx! That takes care of the name, but what about bar|beat|tick? Can we do that?
Derrkins
GuyBarTola
Old 10-17-2008, 07:10 AM
Well, if you're in grid mode, you can simply slide the marker over manually while playing back.
OR, enter spot mode (I think this is the answer you're looking for) and click on the marker to enter it manually. It will move without stopping playback.
Old 10-17-2008, 07:14 AM
Still can't type in the Bar|Beat| value.
Thanx anyway.
Derrkins
GuyBarTola
Old 10-17-2008, 07:28 AM
Sure you can! Just make sure "Time Scale:" is set to "Bars:Beats!"
Old 10-17-2008, 08:09 AM
In the "New Marker" dialogue?!
Derrkins
GuyBarTola
Old 10-17-2008, 08:10 AM
Enter spot mode and click on the marker <<in the marker section of the transport bar (the actual marker)>> to enter it manually. It will move without stopping playback.
Markers (memory locations) NGokhool 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 02-09-2014 07:17 PM
Selecting Between Markers or memory locations wwilentz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-30-2005 11:51 AM
Markers (memory locations) (ProTool HD 6.9.2) Jano Vesta Pro Tools TDM Systems (Mac) 5 09-06-2005 08:01 AM
Memory Locations / Markers not showing up in PT6.4 TWoZ Post - Surround - Video 1 10-19-2004 10:07 AM
Markers / Memory Locations not showing up in PT6.4 TWoZ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-19-2004 10:05 AM
