Go Back   Avid Pro Audio Community > Other Products > The Drum Room
Old 01-13-2018, 10:04 AM
Raoul23 Raoul23 is offline
Default Slate Drums 4 issue
Recently when I open sessions when I’ve used Slate drums 4 the midi is greyed out and I have to duplicate the track to get it to become blue so it will play again. It’s driving me nuts anyone no how to sort this damn issue out??
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 01-13-2018, 01:19 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Slate Drums 4 issue
What happens if you just re-fresh the routing the midi channel to the SD4
Or disable the track and re-enable
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-13-2018, 03:03 PM
Disabling the track then re-enabling does nothing. I’ve not tried the midi routing thing how do I do that ?
Raoul Crane
Old 01-14-2018, 03:46 AM
crizdee's Avatar
On the midi track where is routed to SD just click on the route to SD as if youre routing it again exactly as it was.
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-14-2018, 03:58 AM
Originally Posted by crizdee View Post
Chris
I’m using an instrument track for Steven Slate drums so there is no routing
Raoul Crane
Old 01-14-2018, 04:30 AM
amagras amagras is offline
Go to the Instrument tab (it's the same as showing/hiding the inserts, sends, etc) and re route the midi input to the SSD4 like Chris said.
amagrasmusic.com
FS: Slate Digital, Steven Slate Drums, Eventide, Softube sadateffendy Buy & Sell 7 08-11-2016 05:14 PM
Issue with Slate Drums and PT12 john1192 Pro Tools 12 11 10-29-2015 12:56 PM
Slate Digital and Steven Slate Drums AAX DHL AAX Plug-ins 6 04-22-2013 12:50 PM
PT8 LE and Steven Slate Drums outlaw69uk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 09-30-2010 08:00 AM
Anyone Using Roland TD-9 Drums with Steven Slate Drums? Troy Tracks Studio The Drum Room 2 05-05-2010 06:55 AM
