Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | Dock
  #31
Old 06-12-2019, 10:51 AM
EddieJones's Avatar
Default Re: 10.5 iPad Pro support?
I just received my own 11" iPad Pro so will be looking into it.
  #32
Old 06-24-2019, 01:43 PM
legasafe legasafe is offline
Any word on this? As an iPad Pro 11" user this is holding me back from pulling the trigger on the dock.
  #33
Old 06-24-2019, 02:11 PM
EddieJones's Avatar
Yes, I have mine now. Size wise it even fits in the older Dock mount as its smaller then the 10.5" (smaller bezels) but the power connector hole is slightly obscured by the Dock housing. This will take a it to change in production and its unlikely we cold offer an adapter like before.
That said anyone with a bit of DIY skills could remove the plastic that's in the way. Its not visible from the front of the unit so should be OK.
  #34
Old 06-24-2019, 02:21 PM
robertg robertg is offline
That's pretty disappointing that you don't want to update the adapter, and you are actually asking us to cut into the dock and turn this $1000 device into a DIY project. Really?
Why not redesign this properly so that the ipad sits lower into the dock, therefore not blocking the port.
If you asked me, you're shooting yourselves in the foot long-term by not keeping this product compatible with the latest ipad...
  #35
Old 06-24-2019, 02:53 PM
BScout BScout is offline
Read what he wrote better.
He's saying changing production will not happen immediately to solve this and an adapter alone won't fix it.
Not that they don't want to fix it. He's giving you a work around.
Pro Tools Ult 2019.6, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
  #36
Old 06-24-2019, 02:57 PM
" its unlikely we cold offer an adapter like before. "
That reads like a permanent decision to me..
And "remove the plastic that's in the way" - in other words, 'cut off the plastic, you're on your own.' Not "hang tight for 6 months" or anything like that.
Disappointing..
  #37
Old 06-24-2019, 03:12 PM
Bolded for emphasis.
This means current Docks will not be fixable. Hanging tight for 6 months will not change this. An adapter swap will not work (and I can guess why -- the adapter can only be so thin at the bottom before manufacturing it makes it weak and crackable. So the area near the power port access on the knob frame will need to be widened for new Docks.)
Or you just dremel a bit of plastic out or return your Dock.
  #38
Old 06-24-2019, 03:23 PM
That seems a little far fetched to me. I'm not near the unit right now, but I recall this sort of working with the adapter removed completely. The only thing they may lose or have to make smaller is the logo. I'll have to try it again to confirm
  #39
Old 06-24-2019, 04:16 PM
EddieJones's Avatar
What BScout says. This isn't about the bottom tray/adapter so isn't as easy to fix as before. If you drop the iPad lower by removing the adapter you will cut off part of the screen at the bottom with its smaller bezels.
FYI we don't get any warning from Apple on design changes and it would be cost prohibitive just to scrap all current Docks. As I said we are working on making it compatible for future versions.
  #40
Old 06-24-2019, 04:17 PM
That's fair, in my experience of observing Apple's patterns, I don't see this design changing again for another 5 years at least.. It might get thinner, but the overall shape should remain the same
Support iPad Pro 12.9? Ray Sean Pro Tools | Dock 3 09-20-2016 12:57 PM
iPad Pro 9.7" VS. iPad Air 2 ? reichman Pro Tools | Control 1 08-07-2016 10:46 PM
Anyone have pics of iPad mini and iPad Air side by side! Brandonx1 Pro Tools | Dock 4 06-07-2016 07:03 AM
Does PT First support Avid Control iPad app? atkeyboards Pro Tools | First Discussion 2 03-06-2016 03:41 PM
Ipad 2 is here! nst7 Pro Tools 9 17 03-03-2011 02:40 PM
