Old 02-23-2009, 10:32 AM
audiot audiot is offline
Default Invalid fades on playlist "?"
When I open a PT LE 8 session suddenly following error is reported:
Fade out "Fade CS0vg87PlwSk" at 5:34.875 on playlist "?" is invalid because its left contributor is a fade.
Fade out "Fade pS0vg87PlwSk" at 5:34.875 on playlist "?" is invalid because its left contributor is a fade.
Iīve been working with this session for weeks, without any error!
Suddenly the error appeared out of the blue!
I didīt work in that time area at all!
There is no Fade at this timecode!
I know this issue since PT 7.x
Now we are on Version 8. --------> still unsolved!
This is not the first thread for this problem.
DIGI keeps quiet about it.
So DIGI. What is that? And how can we get rid of it?
Working on large projects really needs confidence in the software weīre using.
You owe us an answer!
Old 02-23-2009, 11:21 AM
DigiTechSupt's Avatar
Default Re: Invalid fades on playlist "?"
Have you tried trashing all fade files and let them be recreated? What about trashing prefs or databases yet?
Avid Audio Tech Support
Support FAQ
Old 02-23-2009, 11:47 AM
Normally this didnīt help under 7.4 and before. The only fix is to go to that TC in the timeline and manually delete the fades that "look weird" and then re-create them manually.
Pretty peinfull when you have 100+ tracks in your session.
The issue has been around since PT5.1 but got less over the years. Not sure if it got worse in PT8 I havenīt hade the move yet.
frank.
Old 02-23-2009, 12:23 PM
This all doesnīt help. The flaw seems to be in the session file
After moving to another workstation the same error appears.
(no matter if LE or HD).
@Frank: there is no Fade here at this TC , not even one that looks weird.
Iīve searched the indicated fades in the finder and then trashed it manually.
Now itīs missing in the timeline altough it wasnīt actually there before..
The error remains the same..
..scary!
Old 02-23-2009, 12:46 PM
..scary!
Yeah, seen that before. Iīve had sessions with major movies that exposed that message every time I opened them. I never cured the error. Nothing helped. But it also didnīt do any harm. I simply got used to it.
Pretty much like those files that always want to be relinked no matter how often you relink them and no matter how often you trash the DBs.
frank.
Old 02-23-2009, 01:14 PM
frank.
yes youīre right. no harm...
......YET!
itīs a question of confidence. Something must be wrong there anyway.
Iīm afraid of another sleeping overkill.
I remember the painful "random edits" issue in 7.3.
Old 02-23-2009, 01:16 PM
Matt Stutter Matt Stutter is offline
The fades may've existed at that timecode point earlier in the sessions history tho, check all hours as well (if you've multiple reels in your session). It's like the fade gets it's time stamp from when it was created, and then conforms or edits move it around.
I went through a bunch of sessions last year that were having massive conforms and found these by zooming in like crazy and tabbing my way through each crossfade - eventually I saw a few that were wiggy, fade was still there - but just looked like half of that crossfade was gone from the waveform... recreate the fade and problem solved..
Not a great workaround.... But a tidy session afterwards!
Old 02-23-2009, 08:46 PM
JWalkerPostAudio JWalkerPostAudio is offline
I read this post this morning and what a coincidence i get this message also. I've never had this before. The message says I have an invalid fade at 347222:59.939 on playlist "?".
Wow that's a lot of minutes!
There's no way I can tab through all these. It's a dialogue session of mine and I make lots of surgical fades.
-Justin
Justin Walker
Old 02-23-2009, 09:10 PM
Fair enough! Mine was an FX predub session, so not quite so many regions ;-)
Old 02-24-2009, 01:58 AM
Cool Crazy workaround
problem avoided here (not solved):
@Matt: Right! It's like the fade gets it's time stamp from when it was created, and then conforms or edits move it around.
Donīt take the indicated time seriously!
If the error suddenly appears, the invalid fade should be somewhere in the area where you have worked lastly!
This should make steps 1-2-3 needless.
Anyway, youīll need Steps 1,2,3 if carry that prob for a long time...
Steps:
1-Create a blank session
2-Session import track by track of the corrupted session. (in relink mode)
3-So you will find the track wich causes the error. Memorize it and close and delete the newly created session
4-Go to the finder and find the indicated fades and delete them from your HD.
5-Open your original session.
6-You will be asked what to do with the missing fade.
DONīt recreate fades automatically,
DONīt find automatically because this will cause PT to crash!
Simply choose: Skip all!
7-Now tab the tracks that caused the error and you will easily find the light blue offline fades.
8-Delete and recreate them manually
9-Session clean!
Has "Some regions had invalid bounds and were adjusted or deleted" been fixed? meech Pro Tools TDM Systems (Mac) 22 06-21-2014 12:47 AM
"Some regions had invalid bounds and were adjusted or deleted" WildHoney Pro Tools TDM Systems (Mac) 243 08-13-2013 08:42 PM
New Mbox Pro "Invalid Authorization Code" envO 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 04-11-2011 09:57 AM
"Some regions invalid bounds and were adjusted or deleted" A duplicate Audio Folder ! acmost Pro Tools 9 0 11-13-2010 05:40 AM
