Yamaha CDR400 SCMS Flags
The MLCD spec sheet claims that V1.4 with the Yamaha CDR400 will write SCMS flags, however MLCD does not recognise this option
What gives? which one is correct,spec sheet or software? As the CDR400 is one of the most popular units for pro use you may expect this feature to be available or if not then maybee someone should be working on a firmware fix if the problem is on Yamaha's side. This is the only problem in an otherwise excelent combination, (over 60 tripple production masters & 300 listening copys in the last year with only one failed disk write) |
Re: Yamaha CDR400 SCMS Flags
Hi Joules.
This is an error in the MLCD spec sheet. The Yamaha CDR400 does not support the SCMS flag. We are updating the sheet to correct this. --Steve
--Steve Rosenthal, Digidesign ETS |
Thanks.
Joules |
Any Red Flags??? | 8mmOverdose | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 02-14-2002 12:27 AM |
PTLE and SCMS | tdowning | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-14-2001 10:52 AM |
SCMS | Ant | General Discussion | 0 | 02-24-2000 04:20 AM |
SCMS and 001 | Ant | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-22-2000 02:58 AM |
SCMS and yamaha 400AT | Stefan Schmahl | Digidesign Hardware & Software | 3 | 10-26-1998 08:32 AM |
