Old 11-13-2000, 10:57 PM
Mark Tandy Mark Tandy is offline
Default Unable to reacquire hardware....
Can anyone Help? I would dearly like to run Pro Tools Free but can't!
I have an Intel Celeron 466 CPU ("Also compatible"),AMI BIOS, Intel 810 chipset, 128 meg of RAM, C-Media sound card, PCI graphics card and (only, although pretty well dedicated) 6gig hard drive (DMA enabled) running Windows 98 SE..
Program seems to install OK. When I run it, all sorts of things seem to load OK and I get the Digidesign blank page. When I try to do anything else, I get the message "DAE error -6008 was encountered" or "Pro Tools is unable to reacquire the hardware and must now exit. More system memory is needed, try quitting other applications, allocating LESS memory to Protools and DAE, or install more memory. Message ID = -6008".
Full duplex is OK - Cooledit Pro works fine.
Any ideas?
Mark Tandy
14/1/2000
Old 11-14-2000, 07:44 AM
DigiTechSupt's Avatar
Default Re: Unable to reacquire hardware....
Hi Mark. One of our engineers, Eric Day, recommended a couple actions to clear the 6008 error :
>PTFree requires a full-duplex sound card >with both playback and recording devices
>specified in Win98's Multimedia control >panel. If you don't have a full-duplex sound >card installed, the -6008 error can result.
I understand you have a full duplex card, so check your multimedia control panel. I hope this helps.
Tom S
Digidesign Customer Service.
Avid Audio Tech Support
Support FAQ
Old 11-15-2000, 03:12 PM
Problem has been fixed by getting latest C-Media sound card drivers from the net.
Old 06-07-2001, 12:30 AM
Kristofer Kristofer is offline
Interesting, I just checked and I have the C-Media chip onboard, time to go hunting... ;^]
Old 06-07-2001, 03:55 PM
Downloaded the current CMedia drivers, no more error -6008. One wrinkle, I had to completely remove the prior device entries (sound card, legacy device, joystick etc.) before the new divers updated properly, and the C-Media mixer had to be disabled in system setup to keep it from loading into the system tray...
HTML code is On
Unable to reacquire hardware mwconn@yahoo.com 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-22-2019 06:50 AM
Unable to reacquire hardware and DAE error 6117. Please help TheSmackPanda Pro Tools 10 2 06-16-2015 02:02 PM
Exiting playback engine! PT unable to reacquire hardware crizdee Pro Tools 10 1 12-17-2011 03:28 AM
"...unable To Reacquire Hardware..." Help, please!! Rooster777 Pro Tools M-Powered (Win) 2 02-27-2008 12:10 PM
unable to reacquire the hardware! "MDW" The cause crizdee Pro Tools TDM Systems (Mac) 4 01-23-2006 06:09 PM
