Old 09-09-2002, 09:03 AM
Soundwise Soundwise is offline
Default Shortcut for breakpoint at insertion?
Is there a shortcut for creating a breakpoint at insertion?
Thanks,
Jari
Jari
Soundwise Ltd
Old 09-09-2002, 11:07 AM
tom_mac tom_mac is offline
Default Re: Shortcut for breakpoint at insertion?
The B key
as long as the single key command is set to the edit window ( little button " A/B " )
they can be pure .......I can be PAID..
Old 09-09-2002, 01:15 PM
DaveP DaveP is offline
I believe the question was how to make an automation breakpoint at the insertion point - not how to make an edit at the insertion point. I don't know of any way to do what you want - though it would be useful.. However, the above two methods will create edits the will not add an automation breakpoint.
Dave Paterson
PT8 HD2Accel QuadG5 OSX10.5.5
Old 09-09-2002, 02:40 PM
Breck Breck is offline
If you'd like to insert an automation breakpoint where the cursor is sitting, try [Apple] + [/].
Works on whatever automation you're currently viewing, and will also follow groups, if you're working on a track that's part of a group, and have that group enabled.
breck@wallstreetproductions.com
Wall Street Productions
Southfield MI
Old 09-10-2002, 12:51 AM
snoopy snoopy is offline
Otherwise Command+E, which can sometimes be faster for those who contantly keep their hand on Command+S.
Colin Miller
Teaboy Audio Recall Sheets
http://teaboyaudio.com
Old 09-10-2002, 02:43 AM
[QUOTE]Originally posted by Breck:
[QB]If you'd like to insert an automation breakpoint where the cursor is sitting, try [Apple] + [/].
Thanks Breck,
That was the one I was looking for!
Jari
Soundwise Ltd
Old 09-10-2002, 07:56 AM
Corey Shay Corey Shay is offline
Is that quick key documented? I've been wondering about how to do just that for quite some time now...
Thanks, Breck!
Old 09-10-2002, 08:51 AM
Breck, where did you find that? I've looked for that for ages and never been able to find it anywhere. Thanks for the info.
Dave Paterson
Old 09-10-2002, 10:38 AM
I'd really like to claim that I have access to secret shortcut- key information... but I don't.
Just pull down the edit menu, place the cursor on 'write automation', and you'll see this shortcut to the right of the 'to current parameter' menu item.
It will write breakpoints to both ends of an edit selection, too. I use it a lot to get a quick ramp-up and ramp- down of a section: make a selection a little bigger than the selection to be ramped and write the automation. Make a selection of only the section to be ramped (inside the breakpoints you wrote first). use the trimmer tool + [option] key to pull up or down the inside breakpoint pair. Very quick!
Southfield MI
Old 09-10-2002, 11:15 AM
I shouldnt try to post while I'm working. When you make the second selection, you must use the [command]+[/] shortcut to create a second set of breakpionts. THEN you can use [option]+ trimmer to pull the inside breakpionts up or down. Duh.
Southfield MI
set a breakpoint to 0 db oNeKOG Windows 3 10-16-2015 08:24 AM
Shortcut- "timeline insertion follows playback"? Big Bad Bill Pro Tools TDM Systems (Mac) 8 02-08-2013 01:50 AM
Timline insertion follows playback shortcut? Mubeau Post - Surround - Video 2 12-11-2005 09:30 AM
Insertion Follows Timeline Shortcut? Eric Bazilian Pro Tools TDM Systems (Mac) 14 06-04-2003 06:30 AM
Automation breakpoint shortcut doesn't work CCash 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-03-2001 12:23 AM
