Old 06-24-2019, 01:35 PM
legasafe legasafe is offline
Default Nudge S3 tracks via jog wheel
Is it possible on the dock to nudge through tracks on the S3 by turning the jog wheel on the dock? A la the old ICON behaviour?
Old 07-23-2019, 08:36 AM
bewk's Avatar
bewk bewk is offline
Default Re: Nudge S3 tracks via jog wheel
I don't know that there's ever been one included in any version of Eucon but there is a way to program a custom wheel command to emulate this with all Eucon devices. I originally made it for the Transport, Artist Mix & Control setup so I'm sure it'd work with the S3. I use it with my Dock/Mix configuration now.
• MacPro (4,1 to 5,1) 12 Core 3.46 GHz // 96GB // AJA Kona LHi // OWC Mercury Elite Pro Quad, USB 3.0, eSATA
• PT HD|Native 2024.3 on macOS 12.7.4 (OpenCore Patcher 1.4.3 on Crucial SSD)
• Avid Dock, iPad 7th gen & EuCon 2023.11
• DADman/Eucon monitoring
• BSS (DAN + 100), QSC DCA 1644, JBL 7 Series
• MTRX Studio // 7.1.4
www.quesound.com
Old 07-25-2019, 08:22 AM
sjgam sjgam is offline
How did you program this?
Old 07-25-2019, 04:40 PM
bewk's Avatar
•First enable "Link Track and Edit Selection" in the edit window. This has to be enabled for this to work.
•Next, in EuControl create a custom Jog Wheel command named "Track Scroll" using the keys "P" for turning left (counter clockwise) and ";" turning right (clockwise). This emulates the up and down navigation of the tracks in the Edit Window.
•Next, assign the Custom Wheel command to a button by selecting a button, clicking "Command" which then prompts you to choose the type of action.
•Select "Wheel" and then choose the wheel to assign it to. In this case choose "Dock Jog". For the "Function" menu navigate to the "Custom" menu selection and there you should find the "Track Scroll" wheel command you created earlier. Select it. Close windows. Done.
It's an on/off toggle with PT so it stays active until you disable it. There isn't a way to differentiate it being on or off visually so you just have to be aware of when it's active. It'd be nice if we could have the buttons change colors or blink to show it's current state in the upcoming version of Control. It seems a little convoluted to build but it works and response is pretty fast too. And this can likely be assigned to and DAW really. Just substitute the keystrokes and it should work just the same.
Cheers,
Chris
www.quesound.com
Old 07-25-2019, 07:44 PM
Cheers,
Chris
Wow cool - thanks for your careful explanation. Interesting your point about working for any DAW. I am on Logic - I suppose I would have to able to set Logic to do the equivalent of your first line - First enable "Link Track and Edit Selection" in the edit window.
Old 07-25-2019, 08:40 PM
bewk's Avatar
Sure thing. Happy to help.
I'm not familiar with how Logic navigates but it seems like there would be an equivalent keystroke for moving around tracks.
www.quesound.com
Old 07-26-2019, 11:45 AM
I will try the arrow keys.
Old 09-06-2019, 07:29 AM
Just got back from vacation and tried using the up and down arrows for custom wheel commands in Logic and can confirm that I can scroll through tracks with the Dock wheel now. Very slick. Thanks again bewk.
Makes me wonder what other tricks I can do in Logic now with that beautiful heavy steel wheel.
Right now using the printed labels on the Dock as guides I have the following for the Wheel in Logic:
1. Jog
2. Shuttle
3. Scrub
4. Zoom Horizontal
5. Zoom Vertical
6. Locator Position, Locator Left and Right
7, Punch Position, Punch Left and Right
8. Marker Position and Length
9 Zoom Track
10. Zoom Wave
11. Nudge/Move Selection
12. And now Track Scroll
What else if Logic relevant?
Jog Wheel, Clip Gain, Nudge Prog Musike Productions Artist Series 2 06-21-2017 09:17 PM
Restoring Tracks, Rainbow Wheel? TonyFlyingSquirrel Pro Tools 12 0 03-28-2015 11:56 AM
Possible to change direction of Nudge 1/Nudge 8/Nudge Bank switches? EricHirsch ICON & C|24 1 08-13-2009 08:07 AM
Can you nudge a region with the scroll wheel? macaholic ICON & C|24 0 08-25-2008 10:59 AM
Can not "nudge" tracks songsforsnakes 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-29-2006 08:37 AM
