Old 07-28-2014, 10:26 AM
yoghurtoth yoghurtoth is offline
Default Finding EZdrummer 2 in Pro Tools LE 8 (setting a path to DLL-file)
I have been trying to use EZDrummer 2 with Pro Tools LE 8, but it doesn't show up in the list of plug-ins. According to the Toontrack website, I will have to do one of the following in order to be able to use EZD as a plug-in:
(1) Customize the EZdrummer 2 installation so that the VST plugin is installed directly to your hosts VST plugin folder, or
(2) use the Plugin manager in your host sequencer to set the path to the EZdrummer 2 plug-in DLL file in its installed location. You can find the location of the EZdrummer 2 plugin at any time by launching the EZdrummer 2 stand alone application and clicking “Help” > “Show Plugin Path.”
Since I've already installed EZD in the default folder, it seems that (2) is my only option. But how do I do it? I can't find anything in the Pro Tools menu that says "set plugin path" or anything similar.
Old 07-28-2014, 06:08 PM
bradch00 bradch00 is offline
Default Re: Finding EZdrummer 2 in Pro Tools LE 8 (setting a path to DLL-file)
Pro Tools LE 8 doesn't use VST plug-ins it uses RTAS plug-ins and if you install the 32 bit version of should be installed in the proper place. Are you trying to insert EZD2 on a stereo instrument track? (It will only show up there)
Pro Tools 12, Studio One V3.x
iMac 27" 5k i7 4Ghz, 32GB RAM 1TB Flash (OS X 10.10.x)
OWC Thunderbay Mini (4TB SSD)
Interface: Antelope Audio Zen-Studio
Presonus Faderport & Faderport 8
Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128
BM5A, KRK VXT4, Equator D5
Macbook Pro 8GB RAM, 512GB SSD Audio(mobile rig)
Old 07-29-2014, 02:30 AM
Thanks bradch00! I've only installed the 64 bit version, it didn't occur to me that only the 32 bit version would work with Pro Tools. Do I still need to install the 32 bit version in a specific folder? And if so, do you know what this folder might be called?
Old 07-29-2014, 06:33 AM
Protools LE 8 is 32 bit and therefore, yup, you'll have to install the 32bit EZDrummer (just use the default installation - next> next> next). Protools didn't hit 64bit until PT11. So give that a try and let us know if you're problem is resolved.
Old 07-29-2014, 01:19 PM
It works now, thanks again!
I've encountered another problem, though. I'm not sure if this is the right forum for this question, but I'll give it a shot:
When I open EZDrummer 2 in Pro Tools LE 8, the EZD 2 window that pops up is too big: the tempo controls among other things are impossible to access because they end up "off screen". Is there anything I can do about this?
Old 07-29-2014, 10:13 PM
Perhaps changing the screen resolution size?
Old 07-31-2014, 12:35 PM
I contacted Toontrack, and they told me to hide the taskbar. It works perfectly now. Thanks again!
Old 01-12-2015, 07:25 PM
dmarkg dmarkg is offline
EZD2 does not fit in my workspace. I'm not getting all of the "Songtrack" feature at the bottom of the screen. I tried changing my system resolutions. No luck, same problem. I have a little PC laptop. EZD worked fine. EZD2 seems to be at a different resolution than Pro Tools Express. Is that possible?
Old 07-26-2017, 06:54 PM
federico federico is offline
Hi, I am having that same problem but the plug in is still not showing in the instruments. PLease help. I have WIN 10, Pro Tools 8.0.5 Mbox 2
Thanks,
Federico
Old 07-26-2017, 07:55 PM
Thanks,
Federico
This would have been better-handled by creating a new thread and including some system details Did you install the RTAS version? Is the newest toontrack stuff even compatible with RTAS? Are you trying to insert on a MONO track? It should go on a stereo instrument track(some VI plugins don't have a mono version) Windows 10 with LE 8.0.5 may not be a compatible combination(not saying it can't work, just that I really don't know). If none of this helps, I would as Toontrack for some help
Optime playback engine setting for Ezdrummer Recon66 Pro Tools M-Powered (Win) 0 12-15-2012 12:47 AM
Is there a VST path setting in PT10? Scorepio Windows 2 07-09-2012 03:47 AM
Re-setting output path irvind 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-29-2009 03:31 PM
The file name and path is 257 characters kimballob 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-22-2009 07:38 AM
Question about finding file location issue hammster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-01-2005 10:40 AM
