Old 01-01-2013, 02:46 AM
tomjackson tomjackson is offline
Default Re: Focusrite Scarlett 2i2 and Pro Tools 9.0.5 on Win 7 64 Home Premium
I kinda like that idea! In fact all I need to do is change the setting in BIOS. I'd like to put the whole room on one big switch. Does anyone know if this feature is available on a Mac Pro running OSX? I don't even know how to get to the BIOS on a Mac Pro.
_______
check here
Old 06-03-2015, 08:11 PM
jham14 jham14 is offline
Default Focusrite 2i2
PT 10 update to 10.3.10 caused several probs. Clock, ASIO settings, PT required PC reboot regardless how I closed it... Andy's 10 step solution did the trick & NO problems now. Thanks
Old 06-04-2015, 05:41 AM
Terry Wetzel Terry Wetzel is offline
Default
I'm late getting in on this thread but I use the 2i4 and I initially had the same or similar problems, (I.E.) change of session from 16 to 48 would cause the dreaded popup interrupting Pro Tools. I really don't remember how I corrected this other than I no longer record at 16bit. I do everything at 48. Now, If the solution given in the original post by AndyMPV in fact solves the problem, I must assume that the entire issue is a Windows issue and not Pro Tools or Focusrite! Should I assume that my assumption is correct? Thanks.
[IMG] code is Off
Pro Tools 11 with Focusrite Scarlett 18i20? hermonmusic Third Party Interfaces 24 06-27-2015 08:53 AM
Pro Tools 9 and Focusrite Scarlett 8i6 - Problems! willyguitar Pro Tools 9 0 11-28-2012 03:57 AM
pro tools 8 windows vista home premium???? bskipacoustic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-02-2010 03:01 PM
Need help with Pro Tools 7.4 on Windows Vista Home Premium therealprawphit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 12-29-2008 10:46 PM
M box 2 Pro tools LE Vista Home premium ed. SHOULD I BUY? Benjo11 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-29-2008 03:28 PM
