  #31
Old 06-05-2016, 07:37 AM
tnipe tnipe is offline
Default Re: Loud clicks when starting or stopping playback
The Weed, thanks, tried out some new things from that thread, but issues are the same unfortunately.
Fiddled around some more with Sonar, but the issues are still there also. If I press stop in a VI track for example, there's a loud pop. The fade out on stop setting won't mask the pops in tracks with release times on a synth, or effect tails.
Appreciate any more suggestions. Seeing that I have the CPU spike issues in PT as well, maybe some CPU settings are the culprit? Though I have speedstepping, turbo boost and c-states disabled in BIOS. Tried to play with other BIOS settings to no avail.
  #32
Old 06-05-2016, 10:17 AM
Tried the Studio One demo as well, I can reproduce this in PT, Sonar and Pro Tools.
  #33
Old 06-05-2016, 03:05 PM
Wizzoboy's Avatar
Wizzoboy Wizzoboy is offline
It sounds like you may have a problem with your interface or its driver as this problem occurs in more than one DAW. Try disconnecting your interface and use your onboard soundcard to see if the problem persists. This will at least eliminate the interface. which would be a common factor across all the DAWs.
Dell Precision 490 Workstation, dual 4 core 5355 Xeon, 16gb Samsung DDR2 ECC Ram - Windows 7 Ultimate - Nvidia GTX 650 - 3 x Internal WD Blacks - PT 2018.3 - Digi 002R - Original Mackie HUI - 3 screens - JBL Monitoring.
Dell XPS 8700 i7-4790 - 24gb RAM - Windows 10 - Nvidia GTX 1060 6GB with Studio driver 546.01 - 2 x Internal Samsung 860 EVO SSDs, and MSATA card - Davinci Resolve Studio 18.6.4 - 3 screens - Blackmagic Speed Editor - MK1 Presonus Faderport - Canon C100 mk2 - Atomos Ninja 2 - Zoom H2n
  #34
Old 06-05-2016, 05:11 PM
I just tried with ASIO4ALL and PT seems to function a lot better, faster and lag-free. There are still pops when starting/stopping, but I guess a lot of people have that due to stopping playback at a point where there's not zero crossing? But no where near as bad with Crimson. I'm eagerly awaiting response from their support departement.
  #35
Old 06-10-2016, 08:09 AM
After trying out a new USB cable I think I'm sorted out.
  #36
Old 06-10-2016, 08:26 AM
mjslakeridge's Avatar
mjslakeridge mjslakeridge is offline
Wow, that turned out to be a simple solution! Since the problem occurred with multiple DAWs, we should have suspected a hardware issue right off the bat, and changing cables is the easiest place to start.
"Whiskey Bottle...Brand New Car...Oak Tree You're in my Way" RVZ
Digi 002 rack , Command 8, Behringer ADA 8000, Tascam M-320B Mixer, Alesis Monitor Two Speakers, Vintage and Modern Tube Amps, Fender American Strat, 1973 Gibson SB-450 Bass, Epiphone Les Paul Traditional Pro, Roland W-30 Keyboard, Preimier XPK Fusion Drum Kit.
  #37
Old 06-10-2016, 11:58 AM
Thanks for helping out, mjslakeridge!
Edit window keeps jumping to bar 45 when starting/stopping transport DJ Hellfire Pro Tools 12 0 01-16-2016 05:07 PM
Starting and Stopping Pro Tools from Venue Scott Fahy VENUE Live Sound Systems 4 02-14-2012 12:43 PM
Cannot control starting and stopping of cursor skydogsound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-03-2008 02:40 AM
Loud Pops at edits(punch points), starting and stopping play dw_deej 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-10-2007 03:57 PM
display starting and stopping murdock 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-13-2000 09:40 PM
