Old 12-07-2004, 12:21 AM
Crackerpants Crackerpants is offline
Default Waveform doesn\'t match audio!
Into a 48K session, I brought in a single mono track (approx 45 minutes) of production audio from a DAT via S/PDIF.
I was slicing the segment into individual regions or 'takes' to bouce for editing. About the 7th segment I noticed the waveform no longer represented what I was hearing in my head-phones. Also I was hearing audible pops in the audio. Almost like single 'frames' of audio from other portions of the region. I say other portions of the region becuase I could recognize the audio as a characters voice but the volume of the pop was nothing like the adjacent audio. It sounded like single frames were inserted into the audio region. The region view does not reflect any cuts around the pop. And as I stated before the region waveform does not reflect the audio in my earphones. Earlier regions on the same track play fine.
Anyone else have this trouble?
- Jackson
ProTools LE 6.4 on a Mac Dual 1.4 G4, 512MB RAM, Digi 002 Rack, dedicated internal ata drive.
Old 12-07-2004, 07:46 AM
hyp0static hyp0static is offline
Default Re: Waveform doesn\'t match audio!
I have had weirdness like that only a couple times. Each time, the only thing I could figure is that my drive/partition was getting close to full and needed to be wiped clean/defragged.
Old 12-07-2004, 09:54 AM
My drive is at less than 10% capacity. Bought it new for this project.
I'll try optimizing the drive. Are you suggesting I wipe it and start all over again?
Thanks for your help.
- Jackson
Old 01-29-2013, 02:43 PM
splaw1 splaw1 is offline
Default Re: Waveform doesn't match audio!
I am having the same problem just without the pops. But the wave form is not syncing with the audio. So far, I have no solid answers from anyone.
Old 01-29-2013, 03:08 PM
Just how was the audio "brought into" your PT session, and is the DAT also 48K. If you used the SPDIF connection, then you should set the DAT machine to be the clock source(SPDIF that is) or you are likely to get clicks and pops. If the DAT was 44.1K, then you would be better using a 44.1K session, or dub through analog connections. As for audio not matching the wave, Hmmm...could be a graphics issue(don't really know)
Importing audio files for remix - convert or set session to match source audio? LSW Tips & Tricks 22 09-09-2014 09:28 PM
Using Elastic Audio match to tempo without affecting the audio Silvio Pro Tools 9 5 06-21-2011 09:41 PM
waveforms don't match audio Jenk2k 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-16-2009 04:05 PM
Audio and waveform don't match in comp tracks joerusi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 02-24-2009 02:12 AM
Waveform doesn't match playback!! Borgbilly Pro Tools TDM Systems (Mac) 6 08-21-2002 06:22 AM
