Old 04-18-2005, 02:27 PM
er3456 er3456 is offline
Default Exporting summed mono files from region list
Hi All,
I've been trying to take a stereo region on a stereo track with a different mic assigned to each channel and "sum" it into one mono .aiff file.
Problem is when I do an export (ctrl-shift-k), and select mono, the result is two separate mono files for the 1eft and right channels (i.e. filename.r and filename.l). What I want is a single mixed-down or summed mono file from the stereo original..
I don't want to Bounce to Disk as that takes much longer to accomplish.
Anyone have any ideas?
Thanks,
er3456
Old 04-18-2005, 06:40 PM
steve at Your Heaven steve at Your Heaven is offline
Default Re: Exporting summed mono files from region list
AS far as I know, as soon as you are altering audio, either by editing or using a plugin or any mixing, Protools only does it in the real-time 'Bounce to disc' mode. Export will create an interleaved audio file of a .L/.R region pair, but not with any effects or edits (except for the selection edit); this is not really an edit, but is a sort of file conversion.
steve
Your Heaven
Bouncing Mono Summed - Do I need to adjust -6db? weezerboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-10-2010 09:41 AM
Exporting Region Groups Vs. Rex Files Kenny Gioia Pro Tools TDM Systems (Mac) 0 03-09-2007 11:17 AM
newbee question - summed mono cunninghamprod 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 12-14-2003 12:39 AM
Bounce Mono Summed CeeBee Pro Tools TDM Systems (Mac) 1 08-24-2002 02:32 PM
Can Master List burn mono files? ArturoBarrientos Digidesign Hardware & Software 1 11-25-1998 09:00 PM
