Re: control 24 and ethernet connection
Well, the key thing is to go into PT peripherals and set it up under ethernet controllers, it should then scan for it and find the ethernet channel and then you add C24 as a device
Hope that helps |
lets see... I had the same problem. I believe that it had something to do with airport. TCP/IP must use ethernet built-in or it won't see the C24. Airport (when installed) somehow replaces this. Sorry, I wish that I could be more specific, but it's been about 7 months since I got my C24.
Paul |
trying to get this beast configured but the Mac doesn't see it, c24 just reads offline.
I turned off airport, set tc/ip to ethernet. Loaded software, ethernet peripheral detection sees 0net. Appletalk is off. Where are the diagnostic functions the manual refers to? Easy fix? I hope? |
Hi Digi:
New user and having the same problem. Mac G-4 - 400 ...9.04 Using Peripherals in 5.1 Get the same reponse... Manual is Skimpy... Please help thanks |
Artist Control / Ethernet Connection and Noise Problems | lberrios1962 | Artist Series | 8 | 05-04-2012 08:20 AM |
C/24 ethernet connection | jmtayloraudio | ICON & C|24 | 3 | 04-23-2010 10:06 AM |
Control|24 losing Ethernet connection | Echo studios | ICON & C|24 | 1 | 04-12-2004 04:17 PM |
Control|24 losing Ethernet connection on TDM/XP | Echo studios | Pro Tools TDM Systems (Win) | 2 | 04-10-2004 08:07 PM |
No Ethernet Connection? | Mark McCabe | ICON & C|24 | 0 | 09-25-2003 11:44 AM |
