Old 02-08-2007, 10:09 PM
JNS JNS is offline
Default \"TRIM\" LED problem
Well, I kept thinking something was wrong and finally got around to checking the LEDs in "test" mode. Sure enough, the TRIM LEDs on channels 1-8 don't work. Everything else lights up fine. Has anybody had any experince with this problem and know if there is a specific harness that might be bad for just these LEDs? Also, how do I access that area in the unit? I'm hoping I don't have to remove the whole thing from the Argosy console to check it.
Thanks,
Jeff
HD3 Accel with 2-192s(expanded) and Rosetta 800, PT 8.0.3cs2/10.5.8 on 8-core 2.8 GHz. MacPro with UAD-2 Solo/Duo and Magma Expressbox4 chassis, Sync I/O, Midi I/O, Control 24;
PTLE 8.0cs3 on Dual-core 2.3GHz. G5(PCIe), 003R
Can't trim the 192 down enough Chris Coleman Pro Tools TDM Systems (Mac) 5 01-13-2009 03:36 PM
volume/trim automation latency problem levelaudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 09-17-2008 02:03 PM
AES/EBU trim? SteveGam VENUE Live Sound Systems 8 04-23-2007 06:53 PM
Problem with trim automation ? frenchman Pro Tools TDM Systems (Mac) 6 04-14-2007 10:35 AM
Problem with TC+E Trim Tool RobbaDobba 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-17-2006 12:54 PM
